OSCTUNE and 12F683
Results 1 to 4 of 4
    Quote Originally Posted by RussMartin View Post
    I'd like to run a 12F683 as close to 131.2 kHz as possible.
    I presume I can select 125 kHz using OSCON.
    But I'm not able to figure out how to use OSCTUNE (page 24 of the data sheet)--or can I even do that to get the desired result?
    Should be able to do that. It doesn't say in that particular datasheet, but I seem to remember reading somewhere that OSCTUNE does about +/-12% worth of tweaking to the internal oscillator. You've got +15 and -15 steps to work with, each 'step' worth about .8% if that +/-12% total is correct.
    So, presuming that the internal oscillator will actually run at exactly 125khz, you need 131.2khz, a 5% increase. 5 / .8 = 6.25, so OSCTUNE = 6 should give you +6.25% from the nominal 125Khz, which comes out to about 132.5khz.
    Set your config's for INTOSC or INTOSCIO...
    Set OSCCON = $11, internal oscillator selected, 125khz selected
    Set OSCTUNE = 6 and assuming the config words took correctly, you should be running at 132.5khz.
    And you'll probably have to change OSCTUNE by 1 or 2 in either direction to get nice and close to 131.2Khz.
    If you set INTOSC instead of INTOSCIO, you should get Fosc/4 on the OSC2 pin, which in your case, you should get 32.8khz. Hope you've got a tight freq counter or a good o'scope!
    Omaha, Nebraska USA
    Thanks for the suggestions. I don't know why I can't find what I need in the 12F683 data sheet but (as I'm sure you've noticed), Microchip's data sheets aren't always as user-friendly as they perhaps could be.
    And I've got both a good (but old) frequency counter (Hewlett-Packard 5300B that last calibrated at 200 ppb) and of course I've got a scope . . . three, right now. (Although my venerable Philips PM3266 is a dinosaur.)
    Interestingly, I intend to use that 32.8 kHz coming out. Although I can probably make do with anything between 32 and 34 kHz, so the tuning may not be as fussy as I am.
    Again, thanks.
    Russ
    N0EVC, xWB6ONT, xWN6ONT
    "Easy to use" is easy to say.
    It might be more accurate to run the PIC as fast as you can (8Mhz on the internal) and write a blinky LED to give you ~32khz on a single pin.
    main: led (whatever pin) = 1
    pauseus 29
    led = 0
    pauseus 28
    1 cycle for each LED=x statement, 2 cycles for goto, 57 cycles for each pause = 61 cycles total.
    8Mhz / 4 = 2 MIPS / 61 cycles = 32,768 Hz.
    Then, between changing the pauseus values, and tweaking OSCTUNE, you should get dead-on exactly what you really want.
