Old and beyond help ?
Results 1 to 40 of 47
    Dec 2007
    Northants England
    Hi
    My secular star of David has 16 arms each with 8 hi-brite leds so the easy way (i think) is a matrix which requires 24 I/O pins. Whilst I could use some other Ports it would be nice the way I have set up the 44 pin demo board to use Port A. Two questions now arise:
    1. Can I use RA6 and RA7 as outputs if there is a xtal connected across them ( do not know what the DC characteristics of a xtal are)
    2. How the devil do I program the 16F887 so that those two pins are available as outputs. I understand that I have to set up the configuration word (register 1) so that bits 2 -0 are 100 which should set the two pins as available for I/O (subject to item 1 ((above)) But what is the syntax for doing this ? I see no rference in the Picbasic manual (or anywhere else) to this. I have looked at examples but cannot figure it out from that. Any advice on this would be appreciated
    Cheers
    Quote Originally Posted by DavidFMarks View Post
    No , you will have to use the internal OSC.
    Cheers
    @__config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    So you did not like the shift registers?
    Dec 2007
    Northants England
    I have set the oscillator to internat but since the crystal is already mounted on the 44 pin board I did not really want to remove it ! .. and yes I dis like the shift register idea but need more time to get my ancient brain around it and to obtain the chips ( Meanwhile Christmas lights are going up all round me !)
    My board did not come with an external OSC mounted, I assumed yours did not also.
    I thought you were asking if the chip was running off the XT could the pins be used as an output.
    Is it Monday or something?
    Dec 2007
    Northants England
    Sorry you are right, there is no crystal (it's my age) I still haven't figured out where the terms in your config expression come from. They are clearly assembler terms of some kind
    Are you using PM or MPASAM for the assembler?
    If you are using MPASAM, ( my choice) goto program files,microchip,mpasamsuite and find the *.inc file for your chip. At or near the end of the file all of the different fuse settings are listed.
    Goes into more detail. Pay close attention to Melanie and Mister_E.
    If you are still unclear let us know.
    (it's my age)
    How old are you???
    Look at my avatar. That is really me
    Dec 2007
    Northants England
    Many thanks for that, Had a quick look at the link ..looks just the thing I wanted, Bit late to study now, bedtime & just got in from g daughters school musical. Age ? put it this way, Faraday hadn't satrted shaving when I got into this game and I aint going to seeing the good old three score years and ten again so its good to be helped by all you patient youngsters ! Thanks again !
