Old and beyond help ?
Results 1 to 40 of 47
    Dec 2007
    Northants England
    Thanks Duncan thats very helpful. Bit of bedtime reading of the data sheet.
    This isn't the star of David that rose in the east this is the one that rises in the west then flashes and rotates etc.
    Thanks for the info
    North Norfolk UK
    Quote Originally Posted by DavidFMarks View Post
    A very secular star that happens to belong to David then, have you envisaged it playing a little tune
    ____
    Three pins are all you need.
    http://www.picbasic.co.uk/forum/showthread.php?t=10200
    Not the star of David though...
    Dec 2007
    Northants England
    Hi
    My secular star of David has 16 arms each with 8 hi-brite leds so the easy way (i think) is a matrix which requires 24 I/O pins. Whilst I could use some other Ports it would be nice the way I have set up the 44 pin demo board to use Port A. Two questions now arise:
    1. Can I use RA6 and RA7 as outputs if there is a xtal connected across them ( do not know what the DC characteristics of a xtal are)
    2. How the devil do I program the 16F887 so that those two pins are available as outputs. I understand that I have to set up the configuration word (register 1) so that bits 2 -0 are 100 which should set the two pins as available for I/O (subject to item 1 ((above)) But what is the syntax for doing this ? I see no rference in the Picbasic manual (or anywhere else) to this. I have looked at examples but cannot figure it out from that. Any advice on this would be appreciated
    Cheers
    No , you will have to use the internal OSC.
    Cheers
    @__config _CONFIG1, _INTRC_OSC_NOCLKOUT & _WDT_ON & _MCLRE_OFF & _LVP_OFF & _CP_OFF
    So you did not like the shift registers?
    Dec 2007
    Northants England
    I have set the oscillator to internat but since the crystal is already mounted on the 44 pin board I did not really want to remove it ! .. and yes I dis like the shift register idea but need more time to get my ancient brain around it and to obtain the chips ( Meanwhile Christmas lights are going up all round me !)
    My board did not come with an external OSC mounted, I assumed yours did not also.
    I thought you were asking if the chip was running off the XT could the pins be used as an output.
    Is it Monday or something?
