trouble with my 16f84a
Results 1 to 27 of 27
    May 2008
    Italy
    pin 4= POSITIVE with 47k resistor
    pin 5= NEGATIVE
    PIN 6 AND 7= LEDs with 470 ohm resistors(and yes, the polarity is correct)
    pin 14 =positive
    pin 15 and 16 =crystal with two 22 pf caps attached to ground
    I have never seen a 47K resistor on reset pin! Tray a 10K
    Pin 5 negative? , surely you mean ground !
    crystal with two 22 pf caps attached to ground (4 MHz?)
    In your program modify pause to 5000, then with a DVM measure port pins. If you see both pins turning on & off then you have a bad ground or a bad resistor or a bad led connected to the led that doesn't work. On the other hand if you don't see the +5 volts ont both pins than you have a bad pic.
    Appart from that I don't see reason for your leds not blinking.
    Al.
    Lightbulb
    Hi, Shawn
    Could you post your HEX code ( not Basic ! ) ???
    I think it's the only way to verify what you put into your Pic ... ( Mr de la Pallice dixit )
    Nov 2008
    Columbus, OH, USA
    Quote Originally Posted by aratti View Post
    Al.
    For this particular PIC at least , it seems to be the norm to use a 47k resistor. The crystal is 4 mhz. And yes,I meant ground:P
    I tried what you recommended , and checked the pins.I am getting a very tiny voltage value ( the last was 35.6 mV.).I've got a feeling I have a couple of bad chips, unless someone can think of another reason for this
    Alain I'm going to post the Hex listing here of the most recent wink program.Thanks for taking a look at it.
    :1000000028288F018E00FF308E07031C8F07031CEA
    :10001000232803308D00DF300F2003288D01E83EB8
    :100020008C008D09FC30031C18288C070318152838
    :100030008C0764008D0F15280C181E288C1C222894
    :1000400000002228080083130313831264000800B1
    :1000500006148316061083128610831686108312E8
    :1000600013308F008830022006108316061083128A
    :10007000861483168610831213308F008830022076
    :060080002828630041285E
    :02400E00FD3F74
    :00000001FF
    Quote Originally Posted by cavity creep View Post
    Do you mean 4.7K
    Nov 2008
    Columbus, OH, USA
    Yes I did.Apologies for the typos.
    Darn, that probably would have been the problem.
    I do not have an 84A to test your HEX with, but I can say the fuses are correct.
    I do not think it will make a difference, but you may try setting the WatchDogTimer to OFF??
    Nov 2008
    Columbus, OH, USA
    Would you believe that did the trick?????
    Thanks you so much! Can you give a little insight into what exactly is going on with the timers?I'm certain I'll run into this again.
    Thanks again to everybody for their insight
    Shawn
    The data sheet says it best. If not, let us know.
    6.10 Watchdog Timer (WDT)
    The Watchdog Timer is a free running On-Chip RC
    Oscillator which does not require any external
    components. This RC oscillator is separate from the
    RC oscillator of the OSC1/CLKIN pin. That means that
    the WDT will run even if the clock on the OSC1/CLKIN
    and OSC2/CLKOUT pins of the device has been
    stopped, for example, by execution of a SLEEP
    instruction. During normal operation, a WDT time-out
    generates a device RESET. If the device is in SLEEP
    mode, a WDT wake-up causes the device to wake-up
    and continue with normal operation. The WDT can be
    permanently disabled by programming configuration bit
    WDTE as a '0' (Section 6.1).
    6.10.1 WDT PERIOD
    The WDT has a nominal time-out period of 18 ms, (with
    no prescaler). The time-out periods vary with
    temperature, VDD and process variations from part to
    part (see DC specs). If longer time-out periods are
    desired, a prescaler with a division ratio of up to 1:128
    can be assigned to the WDT under software control by
    writing to the OPTION_REG register. Thus, time-out
    periods up to 2.3 seconds can be realized.
    The CLRWDT and SLEEP instructions clear the WDT
    and the postscaler (if assigned to the WDT) and prevent
    it from timing out and generating a device
    RESETcondition.
    The TO bit in the STATUS register will be cleared upon
    a WDT time-out.
  1. Code works on 16F84A but not on 16F88?
    By pharaohamps in forum mel PIC BASIC Pro
    Last Post: - 6th November 2009, 18:29
  2. MCLR causing trouble . .
    By shahidali55 in forum General
    Last Post: - 21st December 2007, 12:20
  3. ICSP using a 16F84a to program 24CXX
    By aftab in forum mel PIC BASIC
    Last Post: - 8th April 2007, 11:39
  4. 16F84A and Optrex LCD
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 17th October 2005, 16:08
  5. RS 485 using 16F84A
    Last Post: - 18th May 2005, 14:46
