trouble with my 16f84a
Results 1 to 27 of 27
    Nov 2008
    Columbus, OH, USA
    Well here's the strange thing.Shutting off the watchdog timer works quite well on one PIC.It functions as it is supposed to.However, I tried the exact same thing in the exact same circuit with the other pic, and it doesn't work. Same old problem. Also the book I've been referencing states to set the watchdog and power up timers on.
    Any thoughts?
    Quote Originally Posted by cavity creep View Post
    Any thoughts?
    Just guessing...as usual.
    Try reading the PIC and see if that hex matches the hex generated by the assembler. The config part might not be getting programed correctly.
    If they are not the same.
    Erase all but the chips ID if the EPIC has that setting. Then write to the chip program memory and config settings.
    Nov 2008
    Columbus, OH, USA
    Nope.They look the same.
    Exclamation
    Works fine, as written ...
    Hardware problem ( or config ) ... then !!!
    Have you tried the code example I posted above?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Nov 2008
    Columbus, OH, USA
    I'm going to have to agree with you I think.I suppose I have one good PIC and one bad, but I would think I would have difficulty reading from the ports of aa bad one, or at the very least the programmer would fail to recognize it.Maybe I'm asking for too much.
    Bruce, I haven't tried your code yet.I'm afraid your suggestion got buried in the conversation.I think I'll give it a try and post the results later if I have any success.
    Thanks for everyone for helping me figure this out.I'm sure I'll have many more questions as I go
    Lightbulb Idea
    I'd suggest you to try to place 4.7k and 22 pf as the external RC Clock components ... and give a try like that ...
    no risk !
    Will tell if CONFIG Word is transmitted by the programmer ...
    Just one step further.
    Nov 2008
    Columbus, OH, USA
    no risk !
    Do you mean to use a 4.7 k resistor instead of the crystal and set the oscillator at RC?
  1. Code works on 16F84A but not on 16F88?
    By pharaohamps in forum mel PIC BASIC Pro
    Last Post: - 6th November 2009, 18:29
  2. MCLR causing trouble . .
    By shahidali55 in forum General
    Last Post: - 21st December 2007, 12:20
  3. ICSP using a 16F84a to program 24CXX
    By aftab in forum mel PIC BASIC
    Last Post: - 8th April 2007, 11:39
  4. 16F84A and Optrex LCD
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 17th October 2005, 16:08
  5. RS 485 using 16F84A
    Last Post: - 18th May 2005, 14:46
