Looking for Basic Pic-to-Pic Serial Example
Results 1 to 17 of 17
    Here is a simple hardware sample to receive and send serially.
    It will echo from a terminal program.
    If I remember correctly mister E posted this a long time ago.
    Works well for testing a setup.
    DEFINE HSER_TXSTA 24h ' Enable transmit, BRGH = 0
    DEFINE HSER_SPBRG 129 ' 2400 Baud @ 20MHz, 0.17%
    DEFINE HSER_EVEN    1
    DEFINE HSER_BITS    7
    RCIF   VAR PIR1.5
    SERIALDATA  VAR BYTE
    PAUSE 100
    MAIN:
    IF RCIF THEN
        HSERIN  [SERIALDATA]
        HSEROUT [SERIALDATA]
    GOTO MAIN
    Hello mackrackit,
    With this code can test the operation of a port rs232 with a pic?, I can say that pic would be used and the configuration of the pins is very interesting!.
    Thank you
    Quote Originally Posted by Leonardo View Post
    Hello mackrackit,
    Thank you
    You will need a level converter (max232) between the PIC and PC.
    Also the code was to show how to setup for different bits and so forth.
    Sorry if it confused things.
  1. PIC to PIC "wired" serial one-way communication - SERIN2/SEROUT2
    Last Post: - 14th April 2008, 21:02
  2. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  3. Serial Com Pic to Pic
    By uludere72 in forum mel PIC BASIC Pro
    Last Post: - 31st May 2005, 11:06
  4. Serial Pic to Pic using HSER
  5. Serial communication PIC to PIC help.
    Last Post: - 24th January 2005, 16:45
