I have updated the code as per Bruce and Al's suggestions.
The lights stay on for a short period after the last button is released then go out.
I am interested in reading the value of RB0-RB3 only from PORTB to a byte variable on the first PIC, then sending that over the wire to be written to PORTA on the second PIC.
I ONLY want to read RB0-RB3 though, and ONLY want to write to RA0-RA3. Is there a statement that will allow this?
Charles, I am very interested in using HSERIN in a future version of the project as it would be nice to let the PIC do something else besides wait for a signal. If you can point me at any example code it would be very much appreciated.
Anyway, this is the code so far:
AndCode:'**************************************************************** '* Name : Output15.pbp * '* Author : Greensasquatch * '* Date : 10/11/2008 * '* Chip : PIC16F628A * '* Version : 1.5 * '* Notes : To output a number corresponding to which button * '* : was pressed via serial communication * '**************************************************************** '* This Program is part 1 of 2. The other half receives a '* number and lights a corresponding LED. '**************************************************************** '* REVISIONS: comparators disabled '* '* '**************************************************************** '* '* Connections are as follows: '* '* N/C -01-|####|-18- N/C '* N/C -02-|####|-17- SEROUT Line '* N/C -03-|####|-16- N/C '* MCLR 10K to V+ -04-|####|-15- N/C '* Gnd -05-|####|-14- V+ '* Butt1 -06-|####|-13- N/C '* Butt1 -07-|####|-12- N/C '* Butt1 -08-|####|-11- N/C '* Butt1 -09-|####|-10- Green Power LED '* '**************************************************************** INCLUDE "MODEDEFS.BAS" 'uses internal oscillator (should use crystal but ran out) @ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT CMCON=7 'disable comparators GreenLED var PORTB.4 Butt1 var PORTB.0 Butt2 var PORTB.1 Butt3 var PORTB.2 Butt4 var PORTB.3 Pause 2000 'wait to begin high greenled 'turn on status light Loop: IF BUTt1 = 1 THEN SEROUT PORTA.0,T1200,[9,1] 'sends 9 and 1 if butt1 is high IF BUTt2 = 1 THEN SEROUT PORTA.0,T1200,[9,2] 'sends 9 and 2 if butt2 is high IF BUTt3 = 1 THEN SEROUT PORTA.0,T1200,[9,3] 'sends 9 and 3 if butt3 is high IF BUTt4 = 1 THEN SEROUT PORTA.0,T1200,[9,4] 'sends 9 and 4 if butt4 is high GOTO LOOP end
And thanks again to all who have contributed.Code:'**************************************************************** '* Name : Input15.pbp * '* Author : Greensasquatch * '* Date : 10/11/2008 * '* Chip : PIC16F628A * '* Version : 1.5 * '* Notes : To read a number via serial communication and * '* : light a corresponding LED * '**************************************************************** '* This Program is part 2 of 2. The other half sends a '* number corresponding to a button state. '**************************************************************** '* REVISIONS: comparators disabled, lights out if no signal received '* '* '**************************************************************** '* '* Connections are as follows: '* '* LED3 -01-|####|-18- LED2 '* LED4 -02-|####|-17- LED1 '* N/C -03-|####|-16- N/C '* MCLR 10K to V+ -04-|####|-15- N/C '* Gnd -05-|####|-14- V+ '* Serial In -06-|####|-13- N/C '* Green Power LED -07-|####|-12- N/C '* N/C -08-|####|-11- N/C '* N/C -09-|####|-10- N/C '* '**************************************************************** INCLUDE "MODEDEFS.BAS" 'uses internal oscillator (should use crystal but ran out) @ DEVICE pic16F628A, INTRC_OSC_NOCLKOUT CMCON=7 'disable comparators GreenLED var PORTB.1 LED1 var PORTA.0 LED2 var PORTA.1 LED3 var PORTA.2 LED4 var PORTA.3 NET var byte 'holding variable for input Pause 2000 'wait to begin high greenled 'turn on status light Loop: 'waits for a "9" and writes the next value to NET, turn off LEDs if no signal SERIN PORTB.0,T1200,500,OffLed,[9],NET IF NET = 1 THEN HIGH led1 IF NET = 2 THEN HIGH led2 IF NET = 3 THEN HIGH led3 IF NET = 4 THEN HIGH led4 GOTO LOOP OffLED: low led1 low led2 low led3 low led4 Goto Loop end
