Slapdash, I don't know what kind of blind you are trying to move with a unipolar stepper motor. They should be very light!
Remember that to use an open loop system (relying only on the steps count) with a minimum of confidence, you should use at maximum half the torque the motor can produce.
Even so every open loop system has at least one switch for the zero position. This means that at power up the system search for the zero and set the internal counter offsetting possible drift.
You are using a unipolar stepper which I doubt has the necessary torque for your application, so very likely you will need a gearbox to increase the mechanical torque at the expense of the speed.
Naturally the number of steps per turn of the gearbox shaft should take into account the gearbox ratio.
Further more I suggest you to take into seriuos consideration the needs of two limit switches.
If you could let us know what kind of blind you are moving and the type of stepper you are using it will make life easier in helping you.
Al.
