Relay
Results 1 to 15 of 15
Thread: Relay
Threaded View
  1. #10
    Oct 2008
    I'm doing a temperature control system. Pretty new to PIC programming. I have managed to display temperature on the LCD using an LM35 sensor and a 16 x 2 lcd with a 16F873. I want to add on a 4 x4 matrix keypad so that i can set setpoints to switch a relay and a low warning buzzer I have no idea how to program for the above mentioned add-ons. Please could someone help me. below is my code which will obviously need additions and a scematic of my circuit is attached . Please could somebody help me with this!!
    Define LCD_DREG PORTB
    Define LCD_DBIT 0
    Define LCD_RSREG PORTB
    Define LCD_RSBIT 5
    Define LCD_EREG PORTB
    Define LCD_EBIT 4
    dEFINE LCD_BITS 4
    DEFINE LCD_LINES 2
    adval var word ' Create adval to store result
    temp var word ' Create temp to store result
    temp1 var word ' Create temp1 to store result
    TRISA = %11111111 ' Set PORTA to all input
    ADCON1 = %10000010 ' Set PORTA analog and RIGHT justify result
    ADCON0 = %11000001 ' Configure and turn on A/D Module
    Pause 100 ' Wait 0.1 second
    loop: ADCON0.2 = 1 ' Start Conversion
    AGAIN: Pause 1
    If ADCON0.2 = 1 Then AGAIN ' Wait for low on bit-2 of ADCON0, conversion finished
    adval.highbyte = ADRESH ' Move HIGH byte of result to adval
    adval.lowbyte = ADRESL ' Move LOW byte of result to adval
    Lcdout $fe, 1 ' Clear screen
    temp=50*adval ' Conversion to Degrees
    temp=temp/100
    Lcdout "TEMP = ",DEC temp,$DF,"C" ' Display the value of temp
    temp1 = temp*18 ' Conversion to Fahrenheit
    temp1 = temp1+320
    temp1 = temp1/10
    lcdout $FE,$C0, "TEMP = ",dec temp1,$DF,"F" ' Display the value of temp
    Pause 1000 ' Wait 1 second
    Goto loop ' Do it forever
  1. Need Help
    By PVBiljon in forum mel PIC BASIC Pro
    Last Post: - 29th May 2009, 18:04
  2. Replies: 24
    Last Post: - 7th November 2008, 05:41
  3. Serin to Serin2 ??
    By Gixxer in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 04:56
  4. Serial Relays
    By tazntex in forum General
    Last Post: - 17th May 2007, 18:42
  5. Replies: 22
    Last Post: - 9th April 2007, 16:25
