9V with 4Ah issue
Results 1 to 20 of 20
    Hi, Folks
    So, replacing the 78xx series regulator by a LT 1083 ( 7.5 A )could be an idea ... instead of adding cells.
    but ... I must raise AA cells (even the best : 2800 mah ) DO NOT reach the requested capacity ...
    reminds me someone's projects ... but who's ???
    Are you thinking who I'm thinking?
    Talking
    Hi, Ski
    I'm glad to see your crystal ball went back from servicing ...
    YOU WIN !!!
    I am using the attached adapter. It should empower a circuitry with 4A for one hour (4Ah).
    As a reference I have a 9V block battery, rechargeable, 200 mAh.
    How are you figuring that?
    Batteries in series, yes the volts are added. Amps are not. The amp output will be that of the weakest battery in the pack. If your batteries are 200mAh, then you can run a circuit drawing 200mA for one hour.
  1. 18F2520 ADC issue
    By Acetronics2 in forum mel PIC BASIC Pro
    Last Post: - 24th August 2009, 16:11
  2. Puzzling issue with I2CWRITE to 24LC512
    By aberco in forum General
    Last Post: - 22nd August 2008, 17:47
  3. 9V battery capacity question
    By luminas in forum Off Topic
    Last Post: - 19th August 2008, 16:02
  4. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 08:52
  5. 18F1320 ... Strange Memory
    Last Post: - 9th April 2006, 09:55
