Hi, Ski
I'm glad to see your crystal ball went back from servicing ...
YOU WIN !!!
Hi, Ski
YOU WIN !!!
How are you figuring that?I am using the attached adapter. It should empower a circuitry with 4A for one hour (4Ah).
As a reference I have a 9V block battery, rechargeable, 200 mAh.
Batteries in series, yes the volts are added. Amps are not. The amp output will be that of the weakest battery in the pack. If your batteries are 200mAh, then you can run a circuit drawing 200mA for one hour.
