PBPL 2.50b (possible) For/Next ?BUG? or just the way it is...
Results 1 to 14 of 14
    It will be the weekend before I get back to the bench. I am going to play with it.
    I was playing with a taylor series awhile back and gave up, thought it was me and my bad coding... probably was but maybe it is something with PBPL?
    Not a Darrell Taylor series I hope!!!
    Nope. But might be some relation.
    This Taylor
    http://en.wikipedia.org/wiki/Brook_Taylor
    any resemblance?
    Been playing with this and it is strange.
    Used your vars in this code.
    '18F6680
        Asm
        ERRORLEVEL -205
        Endasm
        DEFINE OSC 20
        @ __CONFIG    _CONFIG1H, _OSC_HS_1H
        @__CONFIG    _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H
        @__CONFIG    _CONFIG4L, _LVP_OFF_4L
        SOUT    VAR PORTF.4
        X       VAR LONG
        MN      VAR LONG
        MX      VAR LONG
        ST      VAR LONG
        mn = -2147483600 'almost max'd out at 31 bits
        mx = 2147483600 'almost max'd out at 31 bits
        st = 1234567 'step size can vary quite a bit
        START:
        SEROUT2 SOUT,16468,["START",13,10]
        GOSUB SKI_COUNT
        SEROUT2 SOUT,16468,["STOP",13,10]
        SKI_COUNT:
      '  For x = mn to MX step 10000'NEVER STOPS
      '  For x = mn to MX step 100000 'NEVER STOPS
        FOR X = -2000000000 TO 2000000000 STEP 2146483647 'STOPS,BUT STRANGE
        SEROUT2 SOUT,16468,[SDEC X,13,10]
        Next x
    The output when it does not stop(roll over)
    2147456400
    2147466400
    2147476400
    -2147480896
    -2147470896
    -2147460896
    -2147450896
    And the STRANGE output when it does stop.
    START
    -2000000000
    146483647
    -2002000002
    144483645
    -2004000004
    142483643
    -2006000006
    140483641
    -2008000008
    138483639
    -2010000010
    136483637
    -2012000012
    134483635
    -2014000014
    132483633
    -2016000016
    130483631
    -2018000018
    128483629
    -2020000020
    126483627
    -2022000022
    124483625
    -2024000024
    122483623
    -2026000026
    120483621
    -2028000028
    118483619
    -2030000030
    116483617
    -2032000032
    114483615
    -2034000034
    112483613
    -2036000036
    110483611
    -2038000038
    108483609
    -2040000040
    106483607
    -2042000042
    104483605
    -2044000044
    102483603
    -2046000046
    100483601
    -2048000048
    98483599
    -2050000050
    96483597
    -2052000052
    94483595
    -2054000054
    92483593
    -2056000056
    90483591
    -2058000058
    88483589
    -2060000060
    86483587
    -2062000062
    84483585
    -2064000064
    82483583
    -2066000066
    80483581
    -2068000068
    78483579
    -2070000070
    76483577
    -2072000072
    74483575
    -2074000074
    72483573
    -2076000076
    70483571
    -2078000078
    68483569
    -2080000080
    66483567
    -2082000082
    64483565
    -2084000084
    62483563
    -2086000086
    60483561
    -2088000088
    58483559
    -2090000090
    56483557
    -2092000092
    54483555
    -2094000094
    52483553
    -2096000096
    50483551
    -2098000098
    48483549
    -2100000100
    46483547
    -21
    02000102
    44483545
    -2104000104
    42483543
    -2106000106
    40483541
    -2108000108
    38483539
    -2110000110
    36483537
    -2112000112
    34483535
    -2114000114
    32483533
    -2116000116
    30483531
    -2118000118
    28483529
    -2120000120
    26483527
    -2122000122
    24483525
    -2124000124
    22483523
    -2126000126
    20483521
    -2128000128
    18483519
    -2130000130
    16483517
    -2132000132
    14483515
    -2134000134
    12483513
    -2136000136
    10483511
    -2138000138
    8483509
    -2140000140
    6483507
    -2142000142
    4483505
    -2144000144
    2483503
    -2146000146
    483501
    STOP
    Those are the results I was talking about.
    Strange....Yes....Unexpected....Not really, especially when dealing with integers, whole numbers, binary conversions, etc.etc.etc.
    I can't think of any really efficient way to check for those kinds of bounding conditions without getting crazy with the code.
    Like I said, it's just one of those things. Doesn't happen too often, and hopefully the person it happens to can understand why it happens and how to avoid it.
    Well... I kind of understand why it rolls over.
    But the results when it does work has me baffled.
    Why?
    Why?
    It's overflowing WAYYY too far, flipping the sign bit, making the For/Next loop think it's still within the boundaries so it keeps adding in the next step value.
    Eventually, it doesn't overflow far enough to either flip the sign bit or when it does overflow, it overflows just enough that the difference between the current count and the max (or min) and the step value goes out of the boundaries of the For/Next loop...
    Doesn't make a lot of sense, does it?......
  1. PBP and PBPL
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 30th January 2009, 18:58
  2. USB PBPL Compile errors
    By Rob in forum USB
    Last Post: - 7th April 2008, 09:18
  3. IF..AND/OR..THEN and PBPL
    By duncan303 in forum mel PIC BASIC Pro
    Last Post: - 25th January 2008, 17:45
