Been playing with this and it is strange.
Used your vars in this code.
The output when it does not stop(roll over)Code:'18F6680 Asm ERRORLEVEL -205 Endasm DEFINE OSC 20 @ __CONFIG _CONFIG1H, _OSC_HS_1H @__CONFIG _CONFIG2H, _WDT_ON_2H & _WDTPS_128_2H @__CONFIG _CONFIG4L, _LVP_OFF_4L SOUT VAR PORTF.4 X VAR LONG MN VAR LONG MX VAR LONG ST VAR LONG mn = -2147483600 'almost max'd out at 31 bits mx = 2147483600 'almost max'd out at 31 bits st = 1234567 'step size can vary quite a bit START: SEROUT2 SOUT,16468,["START",13,10] GOSUB SKI_COUNT SEROUT2 SOUT,16468,["STOP",13,10] END SKI_COUNT: ' For x = mn to MX step 10000'NEVER STOPS ' For x = mn to MX step 100000 'NEVER STOPS FOR X = -2000000000 TO 2000000000 STEP 2146483647 'STOPS,BUT STRANGE SEROUT2 SOUT,16468,[SDEC X,13,10] Next x RETURN
And the STRANGE output when it does stop.Code:2147446400 2147456400 2147466400 2147476400 -2147480896 -2147470896 -2147460896 -2147450896
Code:START -2000000000 146483647 -2002000002 144483645 -2004000004 142483643 -2006000006 140483641 -2008000008 138483639 -2010000010 136483637 -2012000012 134483635 -2014000014 132483633 -2016000016 130483631 -2018000018 128483629 -2020000020 126483627 -2022000022 124483625 -2024000024 122483623 -2026000026 120483621 -2028000028 118483619 -2030000030 116483617 -2032000032 114483615 -2034000034 112483613 -2036000036 110483611 -2038000038 108483609 -2040000040 106483607 -2042000042 104483605 -2044000044 102483603 -2046000046 100483601 -2048000048 98483599 -2050000050 96483597 -2052000052 94483595 -2054000054 92483593 -2056000056 90483591 -2058000058 88483589 -2060000060 86483587 -2062000062 84483585 -2064000064 82483583 -2066000066 80483581 -2068000068 78483579 -2070000070 76483577 -2072000072 74483575 -2074000074 72483573 -2076000076 70483571 -2078000078 68483569 -2080000080 66483567 -2082000082 64483565 -2084000084 62483563 -2086000086 60483561 -2088000088 58483559 -2090000090 56483557 -2092000092 54483555 -2094000094 52483553 -2096000096 50483551 -2098000098 48483549 -2100000100 46483547 -21 02000102 44483545 -2104000104 42483543 -2106000106 40483541 -2108000108 38483539 -2110000110 36483537 -2112000112 34483535 -2114000114 32483533 -2116000116 30483531 -2118000118 28483529 -2120000120 26483527 -2122000122 24483525 -2124000124 22483523 -2126000126 20483521 -2128000128 18483519 -2130000130 16483517 -2132000132 14483515 -2134000134 12483513 -2136000136 10483511 -2138000138 8483509 -2140000140 6483507 -2142000142 4483505 -2144000144 2483503 -2146000146 483501 STOP
