Hserin with Instant Interrupts.
Results 1 to 18 of 18
    Nudge: Disable A/D....;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Doh! PortB...A/D...no kidding...
    Looks like this needs re-named? If PORTS A through Z do not work
    Dec 2003
    Storrs, Ct.
    Default Never crossed my mind!
    I never thought I'd need to set ADCON1 since I'm not using any of PortA.
    Learning something new every day. As always, thanks for the help.
    I'm going to try your method of toggling the LED's Skimask, never seen it done like that, Thanks.
    New working code with one minor change. (Thanks Bruce.)
                         'Hserin with Darryl Taylor's Instant Interrupts
       '   Program to echo incoming serial data
        '   Baudrate : 9600 Baud
           ' MCSP and MPASM, LabX-2, Microcodeloader, PBP2.50
             ' Using PIC 18F2525 @ 4MHZ and bootloader
               ' Using internal USART and MAX232 to interface to Hyperterminal on PC
            DEFINE LOADER_USED 1
            DEFINE HSER_RCSTA 90h ' enable serial port,
            define HSER_TXSTA 24h ' enable transmit,
            define HSER_SPBRG 25 ' set baudrate to 9600
            DEFINE HSER_CLOERR  1 ' automatic clear overrun error
            TRISC  = %10000000    ' PORTC.7 is the RX input, PORTC.6 is the TX output
        '   Serial communication definition
      ADCON1 = %00001111      'Set up ADCON1 register no matter what you're doing!!!!!!
    INCLUDE "MODEDEFS.BAS"       ' Include Shiftin/out modes
    INCLUDE "DT_INTS-18.bas"     ' Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"  ' Include if using PBP interrupts
        '   Variable definition
    RCIF       VAR     PIR1.5     ' Receive  interrupt flag (1=full , 0=empty)
    TXIF       VAR     PIR1.4     ' Transmit interrupt flag (1=empty, 0=full)
    led        var     PORTB.0
    led1       var     PORTB.1
    led2       var     PORTB.2
    holdoff    var     word
    SerialData var     byte
    clear
            INT_Handler   RX_INT,    _Getbytes,    PBP,  no
    @   INT_ENABLE  RX_INT     ; enable RX_INT interrupts
                       ' Subroutine to slow loop down some and toggle heartbeat
    Mainloop:
            for holdoff = 1 to 1000
            pause 1
            next holdoff
            toggle led           'toggle led every loop for heartbeat
            goto Mainloop
               'ISR for RX_int interrupt
    Getbytes:
           While RCIF = 1     ' clear the buffer
           HSERIN 100,error,[Serialdata] ' take it
           hserout [serialdata] ' send it
           Wend
           toggle led2       'led to confirm program went to RX ISR
    @ INT_RETURN
    error:
          Toggle led1
    @ INT_RETURN
    "It will never happen here!" just happened here.
    My thoughts and prayers for Sandy Hook victims and families.
    Quote Originally Posted by ronjodu View Post
    I like that method of using the heartbeat because it allows for an easy change of blink frequency. The LED 'attached' to a timer works also, but it only tells you that the timer is running and an interrupt is working. Generally, I use 2 heartbeats, one for a mainloop, and one for a timer. Mainloop says the program is looping, timer says the PIC is actually running.
    From what I see it's mostly a matter of setting up the defines and running getbytes?
    Is this the barebones of what I need to get data in/out of serialdata?
    As long as data is at portc.7 it continuously runs in the background as an input, loading serialdata while any other code is executing?
    I can then sample serialdata when I need to in my code?
    Getbytes:
    Wend
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 22:43
  3. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 06:13
  4. DT instant interrupts with mister_e keypad
    Last Post: - 26th November 2008, 21:02
  5. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 21:48
