The idea is to read the Current being sent to the reverse lights from the cab. It's actually an analog output from the current sensor, but with the sensitivity cranked up ... the output will be "High" (output saturated) with any current being drawn, and "Low" when there's no current.
Then in the trailer, it turns the lights on/off via serial data to the solid state relay.
For incandescent lights, fast on/off times won't be noticed visually. May cause a little dimming, but it only takes a few milliseconds to send the data so noone will even notice.
This way it doesn't matter what the voltage is on the line. Works on 12v just as well as 24V.
