voltage regulator or resistor for a pic?
Results 1 to 8 of 8
    No limit to the number of 5v regulators you can use, use a TO92 reg for each PIC and LCD backlight. Put them anywhere on the board you want to.
    xnihilo's Avatar
    xnihilo Guest
    Yes, I didn't think about that. Good idea Thanks
    There ya go. They're small enough, you could 'deadbug' them all over the place.
    As far as driving the backlight, yes, you should be able to increase the current limiting resistor value to decrease the backlight down to a more manageable level.
  1. Variable voltage output from a Pic?
    By Dan_lay in forum General
    Last Post: - 24th June 2013, 20:25
  2. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 19:20
  3. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  4. Replies: 3
    Last Post: - 29th October 2006, 09:16
  5. Pic suggestion for high precision voltage measure
    By d1camero in forum mel PIC BASIC Pro
    Last Post: - 10th April 2004, 06:22
