245 led matrix
Results 1 to 12 of 12
Thread: 245 led matrix
    Aug 2008
    Red face duvidas!!
    Caro amigos A emprom e 24lc256 ou 24c256 duvidas
    Ajuda !!
    Quote Originally Posted by cesar35 View Post
    Ok, I'm tired of finding a translator every time...
    But if what you're asking is:
    Can I use a 24LC256 in place of a 24C256?
    Then the answer is...Yes. The datasheets would have told you that the difference between the 24LC256 and the 24C256 is the "L".
    Ok, not really...
    Aug 2008
    Default projeto!!
    The project works well. 24lc256 with.
    you feis the project.
    led blinks for no program to post
    error of door
    I am a usabdo translators ..
    português
    inglês
    Traduzir
    Aug 2008
    Default a juda
    ligo o circuito e perto botão o led a acender.guando eu escrevo a messangem no vp ele da erro de Comunicasão de porta usada .o led bisca varias vezes e não rola messagem . peço ajuda
    turn on the circuit and led to the close button acender.guando I write to keep it in messangem of error of Comunicasão of porta used. bisca the led several times and not roll post.
    Aug 2008
    Unhappy ajuda pequena
    Caros colegas só tenho um duvidas .Precisa mota todos os estagio para funciona o circuito ou com 64 led ele funciona normal .
    o prigado ...
    May 2011
    Default Re: 245 led matrix
    Hello, someone tried to change the 4017 by 74HC595?
  1. led matrix pic 16f84 and 4017 help me please
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 5th February 2011, 01:06
  2. new and need help
    By smeghead in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2008, 21:19
  3. RGB LED Matrix
    By ERIK in forum mel PIC BASIC Pro
    Last Post: - 28th June 2008, 08:01
  4. 245 Led Matrix Display (as constructed by Magu)
    By magu in forum Code Examples
    Last Post: - 29th June 2007, 01:07
  5. LCD will not start
