Denied access to Inc. file change
Results 1 to 3 of 3
    Default Denied access to Inc. file change
    I need to change some of the CONFIG files to setup a 18F26J53 and I have been denied access? If I change them in the the program using @ , the duplicate CONFIGS generate errors. Trying to make changes that can be saved is the problem. I didn't notice this until upgrading to 2.6C with the 4.4beta. Any help?
    Default Re: Denied access to Inc. file change
    Hi fowardbias,
    sounds like you are running Windows and it got an attribute set like system or archive and windows is not allowing you to change it.
    Open up a console (DOS) from the run window, type cmd in XP or command on earlier windows, change directories to the PBP root directory then type attrib -r -a -s -h *.inc , that will remove all attributes set in all the .inc files. OR FROM within windows rt click the file, scroll to properties and uncheck the attributes which cause your pain.
    As soon as I posted I remembered the W7 admin properties needed to be changed (my case) from System to my listed administrator. Right click the file and set it up.....Bingo Done. JC
