Need help on LCD
Results 1 to 7 of 7
    May 2007
    Area 71
    Thanks for your comments
    I changed the dbit to 4 , but nothing come out of the LCD , but LED is blinking
    This is my first time working with 18F2550, is there any other mistake I made?
            __CONFIG    _CONFIG1L, _PLLDIV_10_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_1_1L
            __CONFIG    _CONFIG1H, _FOSC_HS_1H
            __CONFIG    _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _VREGEN_OFF_2L
            __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
            __CONFIG    _CONFIG3H, _PBADEN_OFF_3H & _MCLRE_ON_3H  & _CCP2MX_ON_3H
            __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L  & _DEBUG_OFF_4L
    DEFINE OSC 10
    DEFINE LCD_DREG PORTB     ' LCD data port
    DEFINE LCD_DBIT 4         ' LCD data starting bit
    DEFINE LCD_RSREG PORTB    ' LCD register select port
    DEFINE LCD_RSBIT 0        ' LCD register select bit
    DEFINE LCD_EREG PORTB     ' LCD enable port
    DEFINE LCD_EBIT 1         ' LCD enable bit
    DEFINE LCD_BITS 4         ' LCD data bus size
    DEFINE LCD_LINES 2        ' Number lines on LCD
    DEFINE LCD_COMMANDUS 1500 ' Command delay time in us
    DEFINE LCD_DATAUS 44      ' Data delay time in us
    clear
    porta = 0
    portb = 0
    portc = 0
    TRISA = %00000000               ' Set PORTA to all output
    TRISB = %00000000               ' Set PORTB to all output
    TRISC = %00000000               ' Set PORTC to all output
    LCDOUT $FE, 1
    LCDOUT $FE, 1, "Hello "
    high porta.0
    low porta.0
    Quote Originally Posted by luminas View Post
    Change the D-Bit all you want...
    If you don't change the wiring that goes with it, it ain't gonna work...
    May 2007
    Area 71
    Default Yes it works now
    I forgot to change the wiring hahaha......
    Now it works Thanks again..... have a nice day
    You know, I almost suggested that, but I thought naw, that would be rude . . . DOH!
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
