Beginer Help!
Results 1 to 15 of 15
Thread: Beginer Help!
    Apr 2008
    hi,
    sure I have to return the orignal config. but first of all i should see how it looks like.
    the MCLR was set to off (MCLR_OFF), I try another way to test the circuit in oder to bring back to the original setting.
    thanks for your attention
    Minh LE
    Quote Originally Posted by MINHLE View Post
    hi,
    Minh LE
    Hi Minh LE,
    Actually you do not have to return it to the default settings. The Default settings are there, mostly to help beginning programmers get started, as they likely do not know how to set them in code. You have 3 choices, return them to default settings, comment them out and always set them in your main code, or set them to the setting you use most often and do not include them in your code.
    JS
    Apr 2008
    Hi, Mackrakit,
    I did a mistake:
    when add the @device pic16f628 intrc_osc_noclkout
    and @device 16f628 mclr_off
    in the conf. window should be :
    1- oscillator: intrc clockout
    2- Mclr input pin
    for several ouput pins @ port B, the story is different. I am trying to read in the data sheet of the 16f628.
    regards,
    Minh le
    Are you looking at the TRIS statement? If so, start by putting it near the beginning of your code.
    TRISB = %00000000 ' makes all PORT B pins output
    TRISB = %11111111 ' makes all PORT B pins input
    TRISB = %00000011 ' makes pins B.0 and B.1 inputs, the rest outputs.
    Apr 2008
    Thanks For Your Help,
    It Is As Simple As Assembly Language. And It Is Easy For Me To Follow.
    The Codes That Appear In The Program Of Blinking Port B Like This:
    Trisb, Pr2, Ccpr1l, Ccp1con, T2con. These Scared Me.
    So I Can Continue Now With The Simple Progrmams
    Thanks Agiain,
    Minh Le
  1. Beginer problems
    By luxornet in forum mel PIC BASIC Pro
    Last Post: - 5th February 2010, 05:55
