Yeah... I guess using a variable cap for one of them is a good idea?
I don't think so, but that's just me.
I would think a variable cap would have more +/- over a temperature/voltage/sun angle range () range than a standard cap.
And don't forget...when you're trying out those 'standard caps' and you're looking for accuracy, a lot of caps have tolerances as wide as something like +80%/-20%. You can get ones that are tight, but they'll cost you.
The problem is, if its going to be trial-and-error to work out the right value, i'm going to need a lot of caps.
Microchip also has a couple of app notes on the osc circuitry that you might want to check out
Tim Barr
I don't think the Value matters as much as the 2 capacitors being the same.
Another quote from the datasheet...
Higher capacitance increases the stability
of the oscillator, but also increases the
start-up time.
If you have different value caps then it will change the frequency.
I've been using some 12pf caps that came with the 32768 crystals I bought. And it keeps real good time.
