Need help calculating OSC cap values
Results 1 to 8 of 8
    Quote Originally Posted by Kamikaze47 View Post
    The problem is, if its going to be trial-and-error to work out the right value, i'm going to need a lot of caps.
    That's a fact.
    But you've also got a completely configurable PIC that you can program in a bunch of correction values into.
    (i.e. crystal is off 1%, program in 1% compensation).
    So, as I see it, you only need 2 capacitors and a bit of math.
    Microchip also has a couple of app notes on the osc circuitry that you might want to check out
    Tim Barr
    I don't think the Value matters as much as the 2 capacitors being the same.
    Another quote from the datasheet...
    Higher capacitance increases the stability
    of the oscillator, but also increases the
    start-up time.
    If you have different value caps then it will change the frequency.
    I've been using some 12pf caps that came with the 32768 crystals I bought. And it keeps real good time.
  1. Internal vs. external osc for comms
    By mtripoli in forum mel PIC BASIC Pro
    Last Post: - 29th January 2010, 15:58
  2. WRITECODE stores wrong 14-bit word values in FlashMEM
    By BobPigford in forum mel PIC BASIC Pro
    Last Post: - 26th June 2009, 05:35
  3. Looking at pic basic pro symbol values in mplab 8.15a simulator
    By ukemigrant in forum mel PIC BASIC Pro
    Last Post: - 16th May 2009, 14:18
  4. 16F877A problem: "coupled" digital values
    By Lupo83 in forum General
    Last Post: - 4th December 2007, 13:46
  5. calculating arc tangent
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 14th July 2005, 08:29
