18F1220 programming problem
Results 1 to 9 of 9
    I get the "Overwriting previous address contents" (Error 118), but as I said, other programs also give these error messages and still compile and program correctly.
    Hello jderson,
    It compiles perfectly for me after commenting out the STD configs in the 18F1220.inc file and finds my programmer too, loads the hex too, My money is on Darrel's code is NOT at fault. EDIT: LVDCON = %00000000 is listed twice too
    Thanks Joe! Indeed, the CONFIF1H line is the offender. I don't understand why, but I'll find out.
    Quote Originally Posted by jderson View Post
    CONFIF1H? Huh?
    I'm guessing here, 'cause I haven't/can't look at the 18f1220 inc file at the moment, but the link to the post above most likely will fix your problem.
    applies to the overwriting problem
  1. 16F676 programming problem
    Last Post: - 18th May 2009, 18:39
  2. PIC18F4620 Programming problem
    By JavPar in forum mel PIC BASIC Pro
    Last Post: - 6th December 2008, 05:21
  3. PIC 18f1220 EUSART Baud Rate Cache Problem
    By wklose99 in forum Off Topic
    Last Post: - 15th April 2008, 01:39
  4. Programming Problem with PIC16F819
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 24th July 2007, 19:42
  5. Problem programming the PIC16F648A
    By Edgardo_2 in forum General
    Last Post: - 29th December 2006, 01:02
