Me again, but need REAL help now
Results 1 to 34 of 34
    Blue smoke genie is still in one piece, but just to make sure I changed PIC's and SHT's. (Maybe there is an "I" missing in that sensor code somewhere...........)
    Here is a question. If I wanted to send say "00000101" from a pin on the PIC, how would I do that? SEROUT? and then to receive "01101010" would be SERIN right? Maybe I might have a go at some changes and see what kind of trouble I can get myself into
    Quote Originally Posted by gringobomba14 View Post
    It's all in the PBP manual, check the modifiers.
    Red face
    Ah yes, the standard RTFM answer. In the meantime, another search has produced results of some sort, which has the sensor doing SOMETHING, but I think now it's down to the crazy maths. Watching SCRUBS is a great way of clearing the mind and getting back to work.
    In this case, yes. 3 little letters might help BIN
    Don't forget about overflowing bytes and words...
    Damn straight. Although, I'm not so sure it's so much that it clears the mind as it makes the mind DUMP...
    Talking Beer for everyone!!!!
    I found this code posted by NavMicroSystems, made some SLIGHT changes, and it works perfectly. Cheers to everyone. This works for both the SHT1x and the SHT7x sensors. I have pasted the code below for everyone to see, and play with should the need arise. Thanks again to everyone who spent time trying to make my little project work. Beers are on me (sorry, no delivery outside of my local area)
    '** Pin-Assingments
    DEFINE xtal 4
    Define  LCD_DREG        PORTB
    Define  LCD_DBIT        4
    Define  LCD_RSREG       PORTB
    Define  LCD_RSBIT       1
    Define  LCD_EREG        PORTB
    Define  LCD_EBIT        3
    portB.2=0
    output portb.2
    dta VAR PORTD.0 ' Sensor Data
    clk VAR PORTD.1 ' Sensor Clock
    '** Constants
    cmdtr CON %00000011 ' Command "read temperature"
    cmdhr CON %00000101 ' Command "read humitity"
    '** Variables
    result VAR WORD ' RAW Data from Sensor
    chksum VAR BYTE ' Checksum
    cmd VAR WORD ' Sensor Command
    RHlin VAR WORD ' Rel. Humidity (RH) Linear (% *10)
    RHtc VAR WORD ' Rel. Humidity (RH) temp. compensated (% *10)
    Temp VAR WORD ' Temperature (°C *100)
    DP VAR WORD ' Dewpiont (°C *10)
    '** Temp variables used in div. calculations
    TempDP VAR WORD
    Rchk VAR BYTE
    logEW VAR WORD
    sign VAR BIT
    wy VAR WORD
    wz VAR WORD
    wj VAR WORD
    wx VAR WORD
    i VAR BYTE
    ix VAR BYTE
    bt VAR BIT
    Pause 500
    LCDOut $FE,1,"** SHT 71 **"
    PAUSE 1000
    GoSub init
    cmd = cmdtr
    GoSub readsensor
    Temp=result-3995
    GoSub init
    cmd = cmdhr
    GoSub readsensor
    RHlin=(26542-(54722**result+result))**result-40 ' RH linear
    RHtc=655+(result*5)+(result**15917)
    RHtc=(RHtc**(Temp/10+2480))-(RHtc**2730)+RHlin ' RH temp. compensated
    'GoSub dewpoint
    LCDOut $FE,$80," ",$DF,"C","   ",$25,"RH","   DP "
    LCDOut $FE,$C0,DEC2 (TEMP/100),".",DEC1 (temp/10)," ",DEC2 RHlin/10,".",DEC1 RHLin'," ",DEC2 ABS DP/10,".",DEC1 ABS dp
    GoTo main
    '** Init Sensor
    init:
    High dta
    Low clk
    For i=1 to 10
    High clk
    Pause 1
    Low clk
    Pause 1
    Next i
    Call tstart
    '** start transfer
    tstart:
    High clk
    Pause 1
    Low dta
    Pause 1
    Low clk
    Pause 1
    High clk
    Pause 1
    High dta
    Pause 1
    Low clk
    '** get Data from Sensor
    readsensor:
    GoSub tstart
    GoSub WaitSensor
    ShiftOut dta,clk,1,[cmd\8] ' send command
    Input dta ' wait acknowledge
    Low clk
    While dta=1
    Wend
    PulsOut clk,10 ' send ack
    While dta=0
    Wend
    While dta=1 ' wait for conversion to complete
    Wend
    Low clk
    ShiftIn dta,clk,0,[result.highbyte\8] ' get first byte
    Low dta
    ShiftIn dta,clk,0,[result.lowbyte\8] ' get second byte
    Low dta
    ShiftIn dta,clk,0,[chksum\8] ' get third byte (checksum)
    High dta
    Input dta ' End of Transmission
    Input clk
    '** Dewpoint Calculation
    ' See: SENSIRION Application Note "Dewpoint Calculation"
    ' logEW = (0.66077+7.5*T/(237.3+T)+(log(RH)-2)
    ' DP = ((0.66077-logEW)*237.3)/(logEW-8.16077)
    DewPoint:
    TempDP=Temp/10
    logEW=6608
    sign=TempDP.bit15
    wz=ABS TempDP
    wx=(7*wz)+(wz/2)
    wy=2373+wz
    wj=wx/wy
    For ix=15 to 0 step -1
    wx=(wx//wy)<<1
    wz.bit0(ix)=wx/wy
    Next
    wx=(-sign^((wj*10000)+(wz**10000)))+sign
    logEW=wx+logEW
    wx=RHtc
    wj=(NCD wx) - 1
    wx=wx<<(15-wj)
    wz=0
    For ix=14 to 0 step -1
    wy=wx**wx
    wz.bit0(ix)=wy.bit15
    bt=~wy.bit15
    wx=(wy<<bt)+(bt &&="" wx.bit15)="">
    Next
    wx=((wj*4000)**49321)+(wz**6021)
    logEW=wx+logEW-30000
    sign=logEW.bit15
    logEW=(-sign^(((ABS logEW)+2)/4))+sign
    wx=1652-logEW
    sign=~wx.bit15
    wx=ABS wx
    wy=20402-logEW
    wj=wx/wy
    wx=(wx//wy)<<1
    wz.bit0(ix)=wx/wy
    Next
    DP=((23730**wz)+5)/10
    DP=(-sign^DP)+sign
    WaitSensor:
    result=4096
    Loop:
    result=result-1
    IF dta && result.bit11 Then Loop
    </bt)+(bt>
    Last edited by ScaleRobotics; - 5th January 2011 at 05:02. Reason: added code tags
  1. real time clock
    By maria in forum Code Examples
    Last Post: - 1st March 2022, 13:13
  2. real time clock - PCF8583
    By maria in forum mel PIC BASIC Pro
    Last Post: - 15th April 2010, 16:41
  3. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 17:05
  4. Real time clock... what a headache!
    Last Post: - 8th June 2006, 22:56
  5. Timer in real time
    By martarse in forum mel PIC BASIC Pro
    Last Post: - 29th July 2005, 15:24
