a simple boxe timer (code included)
Results 1 to 25 of 25
    T.Jackson's Avatar
    T.Jackson Guest
    Can you post a readable example using either IF's or Select Case?
    Nope...
    It's a state secret now, top notch double-A rating, return postage included...
    And it's doesn't have IF's, it has a single IF statement
    T.Jackson's Avatar
    T.Jackson Guest
    That's a shame Jeremy, I was going to expose you to the world as border line genius.
    T.Jackson's Avatar
    T.Jackson Guest
    I realize that I'm a bit drunk at the moment, now I'm saying 105+
    T.Jackson's Avatar
    T.Jackson Guest
    The usual suspects.
    Then step away from the keyboard and go chase parked cars or something...
    Talking
    I've already exposed myself. I don't need any help.
    T.Jackson's Avatar
    T.Jackson Guest
    One possible "improved" solution is as follows ...
       Select Case b1
          Case Is < 219
             timerN = 3
             timerAc = 120
             timerBc = 60
          Case Is < 243
             timerN = 2
             timerAc = 180
             timerBc = 60
          Case Is <= 255
             timerN = 1
             timerAc = 600
             timerBc = 180
       End Select
    That code will do exactly the same job as ...
        If (b1 <= 255 And b1 >= 243) Then
            timerN = 1
            timerAc = 600
            timerBc = 180
        End If
        If (b1 <= 242 And b1 >= 219) Then
            timerN = 2
            timerAc = 180
            timerBc = 60
        End If
        If (b1 <= 218 And b1 >= 193) Then
            timerN = 3
            timerAc = 120
            timerBc = 60
        End If
    BUT, it'll probably compile to half the size, run twice as fast, be more readable, easier to comprehend and definitely far easier to maintain.
    Trent Jackson
    T.Jackson's Avatar
    T.Jackson Guest
    I might add also that the same thing is possible using IF's, select case is always more effcient though however.
          for (int i = 0; i < 12; i++)
              sample = tempArray[i];
              if (sample < 0)
                 rangeA++;
              else if (sample < 10)
                 rangeB++;
              else if (sample < 20)
                 rangeC++;
              else if (sample < 30)
                 rangeD++;
                 rangeE++;
    Notice how we start with the smallest number first? Always start with the smallest value first and work downwards with the next biggest value.
    Hope it helps
    Trent Jackson
    Jun 2008
    i'm new to picbasic.
    i didn't know that the "select" statment is so faster and smaller than many "if then" compiled in picbasic [realy i did not look at the select statment ... i've just used the first think i know in picbasic]. it was my mistake that i does't look at the beutiness of my code... even in functions where performance are not needed (like the selection of the time).
    i've just share my code.
    anyway, thank for suggestions.
    any other suggestion will be apriciated.
    p.s. is this code more faster? (no IF needed)
    LOOKDOWN2 W0,>[255,242,218,192,166,144,124,105,80,59,49,40,0],B0
    LOOKUP2 B0,[60,600,180,120,60,60,40,30,20,15,10,45,30],timerAc
    LOOKUP2 B0,[60,180,60,60,60,30,40,30,20,15,10,15,15],timerBc
    LOOKUP2 B0,[6,1,2,3,4,5,6,7,8,9,10,11,12],timerN
    What
    is
    so
    hard
    to
    read
    with
    colons
    I
    think
    they
    help
    make
    the
    code
    MORE
    readable
    if
    used
    in
    the
    right
    place.
    It
    makes
    it
    more
    like
    reading
    a
    book.
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 18:39
  2. Replies: 5
    Last Post: - 24th February 2009, 19:55
  3. Making Program Code Space your playground...
  4. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 23:05
  5. Timer Accuracy
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 06:26
