a simple boxe timer (code included)
Results 1 to 25 of 25
    Jun 2008
    Default a simple boxe timer (code included)
    boxetimer
    Boxe timer is a countdown timer based on PIC 16F84A.
    Through its 7-segments led display it alternates 2 different countdowns.
    In the first mode, called "pause countdown", the display blinks while numbers are shown.
    The second mode is named "working countdown" and shows numbers in a traditional way.
    When the count reach 0, the devices emits a sound using the internal piezo.
    The time is selected using an external switch.
    Code is attached.
    Code is released under the GNU Lesser General Public License.
    COOL.
    Do you have the Pic Basic code so folks around here can work with it?
    COOL.
    It's in the zip file...and it looks a bit goofy to me (But that's just me. It doesn't have near enough colons in it )
    Gotta get new glasses. Did not see it.
    Colons-- Definitely needs a re-write
    hozone, thanks for sharing.
    T.Jackson's Avatar
    T.Jackson Guest
    The project looks good
    Avoid this coding style though ...
        If (b1 <= 255 And b1 >= 243) Then
            timerN = 1
            timerAc = 600
            timerBc = 180
        End If
        If (b1 <= 242 And b1 >= 219) Then
            timerN = 2
            timerAc = 180
            timerBc = 60
        End If
        If (b1 <= 218 And b1 >= 193) Then
            timerN = 3
            timerAc = 120
            timerBc = 60
        End If
    Very inefficient. Suggest rethinking your schema using a "Select Case" structure. No need for the logical AND operator at all. Put your thinking cap on and you should be able to reduce the size of the code by half!
    Trent Jackson
    T.Jackson's Avatar
    T.Jackson Guest
    Jeremy will correct it for you. If he does his IQ is 120+
  1. Elapsed Timer Demo
    Last Post: - 29th October 2012, 17:39
  2. Replies: 5
    Last Post: - 24th February 2009, 18:55
  3. Making Program Code Space your playground...
  4. Interrupt/timer not really interrupting...
    Last Post: - 22nd May 2005, 22:05
  5. Timer Accuracy
    By GEEZER in forum mel PIC BASIC Pro
    Last Post: - 31st March 2005, 05:26
