Need help for reading I2C Sensor
Results 1 to 14 of 14
    Quote Originally Posted by PJALM View Post
    From what I can see in the data sheet you should be using this:
    I2CRead I2C_data,I2C_clock,$F1,[druck,druck2]
    I don't know what the 0 you had there was for but the R/W bit is set by the I2CRead/I2CWrite command, you don't need to set it.
    Probably should be using $F0 instead of $F1 also.
    Mar 2008
    Switzerland
    i did a picture on the KO.
    blue is clock and red are data.
    and i can not read the sensor.
    Mar 2008
    Switzerland
    see datasheet
    Quote Originally Posted by Omalik View Post
    see datasheet
    Right...and PBP handles the R/W bit for you...as stated a few posts above.
    Mar 2008
    Switzerland
    Now the sensor is working well
    Thanks for all your help
    The code I use is:
    I2CRead I2C_data,I2C_clock,$F1,[druck]
    an to calculate the mbar:
    IF druck > 1999 then ' nur positive Druck auswerten
    druck = ((druck - 2000) * 6) + ((druck - 2000) /4) ' * 25 / 100
    druck = 0
    see also the printscreen from the I2C bus.
    Jan 2006
    Toronto
    I am glad to see that you got it working
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 23:42
  2. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Using a TC74A0 with PBP(Thermal sensor via I2C)
    By navaismo in forum mel PIC BASIC Pro
    Last Post: - 1st November 2006, 19:25
