Need help for reading I2C Sensor
Results 1 to 14 of 14
    Jan 2006
    Toronto
    Here is an example of how I use I2C with an EEPROM and the I/O Expander, I hope it helps.
    DEFINE I2C_HOLD 1
    Address VAR WORD
    SCL VAR PORTC.3 ' I2C Clock pin
    SDA VAR PORTC.4 ' I2C Data pin
    Address = 0
    ' Read Password from EEPROM
    ReadPassword:
    Address = 0
    I2CREAD SDA,SCL,$A0,Address,[Password[1],Password[2],Password[3],Password[4]]
    ' Save Password to EEPROM
    SavePassword:
    Address = 0
    I2CWRITE SDA,SCL,$A0,Address,[Password[1],Password[2],Password[3],Password[4]]
    ' Subroutine to handle I2C errors
    I2CError:
    LCDOut $fe,1
    LCDOut $fe,2, "I2C Bus Timed Out" ' I2C command timed out
    Pause 1000
    GoTo loop
    ' Setup I2C I/O Expander
    SetupIOExpander:
    '*** Setup I/O Expander PortA as Output, PortB as Input ***
    I2CWrite SDA,SCL,$40,[6,0,31], I2CError
    Pause 150
    '*** Set the Interrupt Capture Rate to Fast ***
    'I2CWrite SDA,SCL,$40,[11,1], I2CError
    'Pause 150
    '*** Set I/O Expander PortA Outputs to LOW ***
    I2CWrite SDA,SCL,$40,[0,0], I2CError
    Pause 150
    RESUME
    Mar 2008
    Switzerland
    I tray out
    I2CRead I2C_data,I2C_clock,$F1,0,[druck,druck2]
    but it does not work at all. I find a lot of examples for Eeprom but not one for the sensor I use.
    does some have any idea ?
    Jan 2006
    Toronto
    Quote Originally Posted by Omalik View Post
    I tray out
    From what I can see in the data sheet you should be using this:
    I2CRead I2C_data,I2C_clock,$F1,[druck,druck2]
    I don't know what the 0 you had there was for but the R/W bit is set by the I2CRead/I2CWrite command, you don't need to set it.
    also check what you have druck and druck2 declared as, byte or word.
    Quote Originally Posted by PJALM View Post
    Probably should be using $F0 instead of $F1 also.
    Mar 2008
    Switzerland
    i did a picture on the KO.
    blue is clock and red are data.
    and i can not read the sensor.
    Mar 2008
    Switzerland
    see datasheet
    see datasheet
    Right...and PBP handles the R/W bit for you...as stated a few posts above.
    Mar 2008
    Switzerland
    Now the sensor is working well
    Thanks for all your help
    The code I use is:
    I2CRead I2C_data,I2C_clock,$F1,[druck]
    an to calculate the mbar:
    IF druck > 1999 then ' nur positive Druck auswerten
    druck = ((druck - 2000) * 6) + ((druck - 2000) /4) ' * 25 / 100
    druck = 0
    see also the printscreen from the I2C bus.
  1. Need a cheap touch sensor idea.. here it is
    By mister_e in forum Code Examples
    Last Post: - 16th April 2016, 22:42
  2. I2C Master/Slave 16F88/16F767 working code
  3. HARDWARE I2C SAMPLE CODE question
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  5. Using a TC74A0 with PBP(Thermal sensor via I2C)
    By navaismo in forum mel PIC BASIC Pro
    Last Post: - 1st November 2006, 18:25
