LCDOut Woes
Results 1 to 13 of 13
Thread: LCDOut Woes
    I see no LCD defines in your code... please put them in.
    They are in the PICBASIC manual and tons of examples on this forum. Set them up for the way you've got your LCD wired.
    Jun 2008
    Arizona
    Yes, contrast works on three different (brand new) LCD's. All LCD defines are now at default which is:
    PORTA.0 =Data bit 4
    PORTA.1=Data bit 5
    PORTA.2=Data bit 6
    PORTA.3=Data bit 7
    PORTA.4=R/S
    PORTB.3=Enable
    R/W is grounded
    I Disabled MCLR to eliminate the need for pull-up and hassle. I also tried TRISA=%00000000 and TRISB=%00000000. I will post anything you need. Pictures, or anything else. I can even switch to a breadboard and eliminate possibility of circuit board issues (proto board) although I have spent literally 20 hours soldering and de-soldering an looking at every little solder joint, then using PWM and other commands to make sure the chips are good and working properly.
    Thanks for your help on this. Very, very much appreciated...
    Melanie is asking to see the part of your code that looks something like this;
    DEFINE LCD_DREG     PORTB
    define LCD_DBIT     4
    DEFINE LCD_RSREG    PORTB
    DEFINE LCD_RSBIT    1
    DEFINE LCD_EREG     PORTB
    DEFINE LCD_EBIT     0
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    2
    DEFINE LCD_COMMANDUS    2000
    DEFINE LCD_DATAUS   50
    Jun 2008
    Arizona
    define LCD_DBIT     4
    DEFINE LCD_RSBIT    1
    DEFINE LCD_EBIT     0
    DEFINE LCD_BITS     4
    DEFINE LCD_LINES    2
    Yes indeed. I am using the defaults explained in the PicBasicPro manual. It states that you don't need any defines if you are going to accept the defaults which are what I stated above. Is this not the case? I've used the program with LCD defines and without, but I can put them back into the program just to make sure. I have also used defines for a different pin setup that allowed PORTB.3 to be used as PWM output while the other pins ran the LCD.
    Jun 2008
    Arizona
    This should be what I have setup at the moment:
    (CODE)
    DEFINE LCD_DREG PORTA
    define LCD_DBIT 4
    DEFINE LCD_RSREG PORTA
    DEFINE LCD_RSBIT 4
    DEFINE LCD_EBIT 3
    DEFINE LCD_BITS 4
    DEFINE LCD_LINES 1
    (/CODE)
    Apr 2008
    try using with the configuration bits as watchdog timer off and brown out detect off, power up timer on and oscillator as XT
    Jun 2008
    Arizona
    Quote Originally Posted by abidr View Post
    Ok thanks I will try that. I am still working on it. I wound one coil by keeping track of counts in memory and I already have problems, I missed about 30 turns out of 900 lol! My backpack LCD (Seetron) was purchased back in 1999 and I found it works but the 16C54 it uses is bad (sends out garbage on the 3rd character placement and further) so I will have to get back on the LCDout unit using 16F628.
    I will try this tomorrow and get back to you. Thanks very much for the input it is very much appreciated.
  1. Timer + rc5
    By naga in forum mel PIC BASIC Pro
    Last Post: - 19th November 2009, 07:56
  2. need help in coding..
    By daphne8888 in forum mel PIC BASIC
    Last Post: - 19th March 2008, 07:31
  3. Help GPS read with serin
    By leinske in forum mel PIC BASIC Pro
    Last Post: - 5th September 2007, 02:33
  4. Crystalfontz LCD
    By jman12 in forum mel PIC BASIC Pro
    Last Post: - 9th February 2007, 15:04
  5. having problems with Hantronix 20x4 lcd
    By Rhatidbwoy in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2005, 12:22
