Help reading DS1990A ibutton with PIC
Results 1 to 11 of 11
    May 2008
    ccs does not use the same syntax?
    So can anyone help me with how to change the code to ccs?
    Quote Originally Posted by konzen View Post
    If you don't know that C is different than Basic, major differences in syntax and so on...maybe you've got a bit more homework to do...
    As far as changing the code over...if you knew one or the other it might be possible. If you want somebody to do it for you? rotsaruck...
    May 2008
    the code on that link is in C. And i think its in CCS compiler format.
    So can anyone help me with the code? I've run it and it doesn't seem to be working.
    Don't you think it wouldn't be much more efficient to drop a mail to the code author ???
    May 2008
    yeah I thought of that but apparently he is not a member as I can't access his profile.
    forgive my ignorance but I don't think he's a member?
    Probably his account have been deleted after all this time. The only place i would suggest you is the CCS forum. Sure you'll find the info you need over there.
    http://www.ccsinfo.com/forum/
    May 2008
    Thanks.
    I found the full code from the example files in the CCS folder!! They were there all along!!
    Will try them out soon.
  1. Reading PIC serout in hyperterminal
    By financecatalyst in forum Schematics
    Last Post: - 22nd October 2009, 16:13
  2. Connecting ibutton to pic!
    By jkbpower in forum Schematics
    Last Post: - 4th December 2008, 08:09
  3. Reading a slave USB with a pic
    By pcaccia in forum mel PIC BASIC Pro
    Last Post: - 25th October 2008, 13:00
  4. Writing & Reading to iButton EEPROM
    By crhomberg in forum Code Examples
    Last Post: - 6th October 2008, 20:40
