ccs does not use the same syntax?
So can anyone help me with how to change the code to ccs?
If you don't know that C is different than Basic, major differences in syntax and so on...maybe you've got a bit more homework to do...
As far as changing the code over...if you knew one or the other it might be possible. If you want somebody to do it for you? rotsaruck...
the code on that link is in C. And i think its in CCS compiler format.
So can anyone help me with the code? I've run it and it doesn't seem to be working.
yeah I thought of that but apparently he is not a member as I can't access his profile.
forgive my ignorance but I don't think he's a member?
Probably his account have been deleted after all this time. The only place i would suggest you is the CCS forum. Sure you'll find the info you need over there.
http://www.ccsinfo.com/forum/
