PIC16F690 - 24LC08B: they won't talk...
Results 1 to 17 of 17
    xnihilo's Avatar
    xnihilo Guest
    Default i2cwite not writing... some ideas...
    Sayzer,
    There IS a
    DEFINE OSC 8
    in my program, i just forgot to paste it...
    Here are some things i will have to check/do:
    - solder a 8 pins socket on a protoboard instead of breadboard and solder connexions
    - use 2k wpu only on sda instead of a 4.7k wpu on each scl and sda
    - swap with another pic16f690 in case the one i use is defect
    - swap with another 24lc08b in case the one i use is defect
    - try a huge pause 50 instead of pause 5 after the i2cwrite in case it is a timing problem
    - declare the eeprom address variable as a word instead of as a byte
    - declare "eep_address" instead of "ep_address" (i wonder how i didn't see this typing error!)
    - try to program a specific value in byte 0 of the eeprom using my pic-pg2 programmer and see if i get this value back with an i2cread
    besides this i don't se what i can do...
    Quote Originally Posted by xnihilo View Post
    See pages 7 and 10 of this datasheet:
    http://ww1.microchip.com/downloads/e...Doc/21710H.pdf
    EDIT: I get the feeling that you're doing a lot of 'thinking out loud' and not a lot of 'doing' (as indicated by the post below).
    Not a good way to go about things...
    Jan 2006
    Istanbul
    Sayzer,
    There IS a
    DEFINE OSC 8
    How did you NOT get an error then?
    Also, when you change your code after you asked some questions about it, it is difficult to follow.
    Paste a new one with your modifications, so that we can see what the difference was.
    xnihilo's Avatar
    xnihilo Guest
    "ep_address" instead of "eep_address" didn't generate an error because it is a paste error only. I selected the block starting from the 2nd chara of the line, so it is alright, the variable name is right.
    I changed slightly the code:
    eep_address VAR WORD
    instead of BYTE
    and:
    I added:
    ADCON0.0 = 0 'turn adcon off
    Things I wanted to do:
    -> DONE
    -> DONE, but I used 2K on each of the SCL and SDA pins
    -> DONE
    -> DONE
    -> DONE
    ->DONE
    -> DONE, no error there in fact
    code is:
        'routine that checks if the external eeprom (the mag) is connected to the supplier
        'it writes than reads back the test value (33)
        checkwrite = 33
        eep_address = 0     'use storage byte 1 of 255 fo rthe test
        LCDOUT $fe,1,"CTRLbyte:",#eep_control
        PAUSE 2000
        I2CWRITE PORTC.6,PORTC.7,eep_control,eep_address,[checkwrite]    'store maxitem value in the mag external EEPROM
        PAUSE 50        'hadware dependent
        LCDOUT $FE,1,"Wrote:",#checkwrite,"@",#eep_address
        PAUSE 2000
        I2CREAD PORTC.6,PORTC.7,eep_control,eep_address,[checkwrite]    'store maxitem value in the mag external EEPROM
        LCDOUT $fe,1,"Read:",#checkwrite,"@",#eep_address
        PAUSE 2000
        IF (checkwrite != 33) then
            LCDOUT $fe,1,"couldn't write"
            PAUSE 4000
            checkwrite = 0
            GOTO endofroutine
        checkwrite = 66
    RESULTS:
    The output on LCD is:
    "wrote:33@0"
    "read:0@0"
    "couldn'twrite"
    So, back to the starting point but this time I have no idea what I could change.
    Is it the wires length? Did I failed to set some registers? ...
    I'm lost... And angry.
    My circuit is useless if I can't write to external eeprom...
    And pin 7 on the eeprom is connected to _______________
    EEP_ADDRESS MUST be a byte... Something change in the ControlByte when you want to access the other EEPROM Page (Banks). Page 6 of the above data sheet
    One more, you haven't disable AN<9:8> yet, and it's your I2C lines... check ANSELH settings.... probably THE MAIN reason why you always have 00 as results. If it was the WP pin of the EEPROM, you would probably have FF all the time. if the device is already blank.
    Yep, sure enough... Figured Microchip should know better than to place 'WORD' above those on page 7 and 10...and the 'sheet even shows 8 bit slots in the diagram...
    There's always something to screw the understanding here and there huh?
    Some call it ControlByte, some other Control Word
    Some says Address, some Adress word for 8 bits address...
    and so on... nice world... thanks to my avatar
    xnihilo's Avatar
    xnihilo Guest
    to gnd of course. i do not want to write protect the chip.
  1. PIC16F690 code help please
    By hysteria92 in forum mel PIC BASIC
    Last Post: - 24th February 2010, 17:17
  2. PIC16f690 LCD Not Working
    By hhosteam in forum mel PIC BASIC Pro
    Last Post: - 3rd June 2009, 07:26
  3. Replies: 1
    Last Post: - 19th February 2009, 14:35
  4. Replies: 0
    Last Post: - 13th February 2009, 04:34
  5. gps rikaline x5 to pic16f690
    Last Post: - 9th May 2008, 12:21
