Final Button Code
Results 1 to 18 of 18
    May 2008
    Texas
    I was refering to my button command. Should I start the port high and pull it low or start low and pull high based on this bit of code?
    delay = 0
        Button Temp_Up, 0, 255, 0, delay, 0, Up_Loop
        button Temp_Down, 0, 255, 0, delay, 0, Down_Loop
    Up_Loop:
        If Temp_Up = 0 Then
            Setpoint = Setpoint + 1
            lcdout $fe, 1, "Setpoint = ", Setpoint
            Pause 1000
        Else
            Goto Start_Convert
        Endif
        Goto Up_Loop
    Down_Loop:
        If Temp_Down = 0 Then
            Setpoint = Setpoint - 1
            Pause 1000
        Else
            Goto Start_Convert
        Endif
        Goto Down_Loop
    Well, I was referring to your schematic. The way you code depends on the way you wired it up...
    Quote Originally Posted by WarPony View Post
    delay = 0
    Up_Loop:
        If Temp_Up = 0 Then
            Pause 1000
        Else
            Goto Start_Convert
        Endif
        Goto Up_Loop
    Down_Loop:
            Pause 1000
        Else
            Goto Start_Convert
        Endif
        Goto Down_Loop
    Hello WarPony,
    You have written your code, If X=0 true, then do something, so you would pull the ports up to supply + with a resistor or WPUs, and the if / then loop would be true when the switch grounds it. Did I answer the right question or are you asking which way is better ?
    May 2008
    Texas
    I am getting all twisted up with the button code and loop. I havent added my switches to my circuit yet. I just want 1 to be added to or subtracted from my setpoint when one of the two switches is pressed.
    When we say pullup/pulldown, generally we're referring to the state of the pin when the switch isn't being actuated.
    Usually, a person will put a resistor (4.7K-10K, whatever), from the pin to Vdd, and the switch is wired in to ground that pin. Since the resistor runs from the pin to Vdd, the pin is high with the switch open, low with the switch closed.
    So, if you want to use the button command, that's great...but why not play around with it without using the button command so you can understand it's inner working a bit better.
    i.e.
    loop:
    if switch1 = 0 then setpoint = setpoint - 1
    if switch2 = 0 then setpoint = setpoint + 1
    ......blah blah blah....
    Yes, a loop like this will likely execute entirely too fast, and will most likely cause the setpoint value to 'wrap around'...but that's what 'pause' can be used for.
    May 2008
    Texas
    Talking aha
    Why couldnt the pbp manual explain it like that?
    Thanks skimask
    I will finish my circuit and let you know how it went.
    Wink Some ideas to pick up ...
    Hi WP
    I played a bit with the code these two days ...
    that gives the following ...
    ' Thermostat F84 test sur EasyPic5
    ' Thermostat 16F877a + DS 18B20
    @ __config _HS_OSC & _WDT_ON & _PWRTE_ON & _BODEN_ON & _LVP_OFF & _CP_OFF
    '*                  LCD Defines for EasyPic5                                 *
        DEFINE LCD_DREG PORTB               ' I/O port where LCD is connected
        DEFINE LCD_DBIT 0
        DEFINE LCD_RSREG PORTB
        DEFINE LCD_RSBIT 4                  ' Register select pin
        DEFINE LCD_EREG PORTB
        DEFINE LCD_EBIT 5                   ' Enable pin
        DEFINE LCD_BITS 4                   ' 4-bit data bus
        DEFINE LCD_LINES 2                  ' LCD has 2 character lines
        DEFINE OSC 8
        DEFINE BUTTON_PAUSE 100
    'Define	    LCD_DREG	PORTD
    'Define	    LCD_DBIT	4
    'Define	    LCD_RSREG	PORTE
    'Define	    LCD_RSBIT	0
    'Define	    LCD_EREG	PORTE
    'Define	    LCD_EBIT	1
    Temp_Down     	VAR PortA.0    	 'Temp down button input port
    Temp_Up      	VAR PortA.1    	 'Temp up button input port
    G_LED         	VAR PortC.0   	  ' Green LED output cold needed
    Relay_Cold		VAR PORTC.1
    R_LED        	VAR PortC.6   	  ' Red LED output  hot needed
    Relay_hot		VAR PortC.7
    DQ           	VAR PortE.2   	  ' One-wire Data-Pin "DQ" on PortE.2
    'Temp_Down    	VAR PortB.3    	 'Temp down button input port
    'Temp_Up       	VAR PortB.2    	 'Temp up button input port
    'R_LED        	VAR PortB.0   	  ' Red LED output
    'G_LED        	VAR PortB.1   	  ' Green LED output
    'DQ            	VAR PortC.0   	  ' One-wire Data-Pin "DQ" on PortC.0
    Busy          	VAR BIT        	 ' Busy Status-Bit
    delay         	VAR BYTE       	 'Button working variable
    Dummy         	VAR BYTE       	 ' Dummy for Div32
    Loscale			VAR BYTE
    Hiscale			VAR BYTE
    Decal			VAR BYTE
    Tempeff			VAR WORD
    Setpoint      	VAR WORD
    R_Temp        	VAR WORD        	' RAW Temperature readings
    TempC         	VAR WORD        	' Temp in deg C
    Float         	VAR WORD       	' Holds remainder for + temp C display
    ColdStart		VAR BIT
    Sign			VAR BIT
    Cold_Bit      	VAR R_Temp.Bit11	' Sign-Bit for +/- Temp. 1 = Below 0 deg C
    ADCON1 = 7			          	' Set PORTD and PORTE to digital
    CMCON  = 7						' Comparators OFF
    PORTA = %00000011
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    TRISA = %00000011
    TRISB = 0
    TRISC = 0
    TRISD = 0
    TRISE = %00000010
    DS18B20_9bit  CON %00011111   	' 93.75ms, 0.5°C
    DS18B20_10bit CON %00111111   	' 187.5ms, 0.25°C  <-- My favorite
    DS18B20_11bit CON %01011111   	' 375ms,   0.125°C
    DS18B20_12bit CON %01111111   	' 750ms,   0.0625°C  (default)
    Setpoint = 200                                  'Default setpoint on start up
    ColdStart = 1
        LCDOut  $FE,1                                     'Clear LCD
        PAUSE 750
    'Chargement motifs en CGRAM
      LCDOUT  $FE,$40,$00,$00,$00,$00,$00,$04,$04,$04  ' Cust Char #0
      LCDOUT  $FE,$48,$00,$00,$00,$04,$04,$04,$04,$04  ' Cust Char #1
      LCDOUT  $FE,$50,$04,$04,$04,$04,$04,$04,$04,$04  ' Cust Char #2
      LCDOUT  $FE,$58,$04,$04,$0E,$0E,$0E,$1F,$1B,$11  ' Cust Char #3
      LCDOUT  $FE,$60,$11,$1B,$1F,$0E,$0E,$0E,$04,$04  ' Cust Char #4
        OWOUT DQ, 1, [$CC, $4E, 0, 0, DS18B20_10bit]    'Skip ROM search and write 10bit 														resolution to scratch pad
    Start_Convert:
        OWOUT   DQ, 1, [$CC, $44]                       ' Skip ROM search & do temp conversion
        delay = 0
        Button Temp_Up,   0, 255, 0, delay, 1, Up_Loop
        button Temp_Down, 0, 255, 0, delay, 1, Down_Loop
    ' Check for still busy converting ( ~ 4500 fois ... )
    waitloop:
    		INPUT DQ
    		If NOT DQ Then waitloop
        OWOUT   DQ, 1, [$CC, $BE ]                       ' Skip ROM search & read scratchpad 														memory
        OWIN    DQ, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]' Read two bytes / end comms
    Convert_Temp:
    	IF R_Temp.15 THEN
    		 R_Temp = ~R_Temp + 1
    		 Sign = 1									'Signe -
       		 Sign = 0									'Sign  = "+"
        TempC =  ( R_Temp & $7FF ) >> 4   				' Partie Entière
        Float = ((R_Temp.Lowbyte & $0F ) * 25 )>> 2     ' Partie décimale 100èmes
        Tempeff = TempC*10 + Float/10					'Préparation 1/10 degrés
    	gosub Aff
     GOTO    Start_Convert
    Up_Loop:
        If Temp_Up = 0 Then
            Setpoint = Setpoint + 5
            lcdout $fe, $C0, "Setpoint = ", DEC2 (Setpoint/10),".",DEC1(SetPoint // 10)," "
            Gosub Show
            Pause 500
        Else
            Goto Start_Convert
        Endif
        Goto Up_Loop
    Down_Loop:
            Setpoint = Setpoint - 5
            Pause 500
            Gosub Show
        Else
            Goto Start_Convert
        Endif
        Goto Down_Loop
    '                              AFFICHAGE
    'Motifs
    'Small bar     LCDOUT  $FE,$40,$00,$00,$00,$00,$00,$04,$04,$04  ' Cust Char #0
    'Mid bar       LCDOUT  $FE,$48,$00,$00,$00,$04,$04,$04,$04,$04  ' Cust Char #1
    'Big bar       LCDOUT  $FE,$50,$04,$04,$04,$04,$04,$04,$04,$04  ' Cust Char #2
    'Arrow 		   LCDOUT  $FE,$58,$04,$04,$0E,$0E,$0E,$1F,$1B,$11  ' Cust Char #3
    'Inv Arrow     LCDOUT  $FE,$60,$11,$1B,$1F,$0E,$0E,$0E,$04,$04  ' Cust Char #4
    Aff:'Affichage temp
    'préparation chiffre : sign = 1 = valeur négative
    Loscale = ( TempC /5 + Sign ) * 5  + Sign << 7
    Decal = 0
    Decal	= ( TempC // 5 ) << 1
    IF Sign THEN
    	IF Float > 25 AND Float <= 75 then Decal = Decal - 1
    	IF Float > 75 Then Decal = Decal - 2
    	IF Float > 25 AND Float <= 75 then Decal = Decal + 1
    	IF Float > 75 Then Decal = Decal + 2
    Hiscale = (TempC /5 + ( Sign ^1)) * 5 + Sign << 7
    'Impression valeurs 1ère ligne
      LCDOUT	$FE, $81 ,SDEC2 Loscale,178,"C"," ",SDEC TempC,".",dec2 Float,$FE,$80 + 12,SDEC2 Hiscale,178,"C"
    'Impression échelle 2ème ligne
     LCDOUT	$FE,$C0,$01,$00,$02,$00,$01,$00,$01,$00,$01,$00,$01,$00,$02,$00,$01,$00
    'Impression index
     IF Tempeff < Setpoint THEN
    	LCDOUT	$FE, $C2 + Decal,$03				'Index Chauffage
    	LCDOUT	$FE, $C2 + Decal,$04				' Index Refroidissement
    Show:
    	high R_LED                                   ' Turn on Red LED C0  and turn off Green 														LED C6
    	low G_LED
    	IF Coldstart THEN Relay_hot = 1 : Relay_cold = 0 : Coldstart = 0
        High G_LED                                   ' Turn on Green LED C6 and turn off Red 														LED C0
        low R_LED
        IF Coldstart THEN Relay_hot = 0 : Relay_cold = 1 : coldstart = 0
    Drive:
    	IF Tempeff < (Setpoint - 5) AND Relay_hot = 0 THEN Relay_hot = 1 : Relay_cold = 0  'C7
    	IF Tempeff > (Setpoint + 5) AND Relay_cold = 0 THEN Relay_hot = 0 : Relay_cold = 1	'C1
    Some little improvements to work further on for the drive section ...
    but the idea is here ...
    May 2008
    Texas
    Thumbs up
    meersee buukuu alain (bad french accent)
    gonna grab some of that code you worked up...this is for residential so the temps I am working with will be from about 60 degrees F to 80 degrees F for setpoints and 20 degrees F to 120 degrees F for the outside reference temp.
    thanks again
    Bryan
    Because PicBasicPro isn't basic digital electronics.
    You get basic digital electronics from a book called 'Basic Digital Electronics'.
    May 2008
    Texas
    Read that book....didnt hold my attention...maybe thats my problem...haha
  1. TSA5512/5511 code for PIC16F877/84
    By Marin in forum mel PIC BASIC Pro
    Last Post: - 24th August 2013, 07:16
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  5. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
