Display "0" on LCD
Results 1 to 19 of 19
    For one thing, the PBP manual doesn't say it specifically, but LCDDATA_US is a byte value. 1200 would actually be 176.
    Have you got a pullup on A.4?
    Try this then:
    DEFINE LCD_DREG	PORTA	'Define PIC port used for LCD Data lines
    DEFINE LCD_DBIT	0		'Define first pin of portb connected to LCD DB4POTSETTTT
    DEFINE LCD_RSREG PORTA	'Define PIC port used for RS line of LCD
    DEFINE LCD_RSBIT 4		'Define Portb pin used for RS connection
    DEFINE LCD_EREG	PORTB	'Define PIC port used for E line of LCD
    DEFINE LCD_EBIT	3		'Define PortB pin used for E connection
    DEFINE LCD_BITS	4		'Define the 4 bit communication mode to LCD
    DEFINE LCD_LINES 2		'Define using a 2 line LCDRefTime
    DEFINE LCD_COMMANDUS 5000	'Define delay time between sending LCD commands
    DEFINE LCD_DATAUS 200	'Define delay time between data sent.
    i var word : trisb.7 = 0 : portb.7 = 1
    pause 1000 : lcdout $fe , 1 : pause 1000
    for i = "a" to "z" : lcdout $fe,$80,i,i+1,i+2,i+3,i+4,i+5,i+6,i+7
    pause 500 :next i
    Dec 2005
    Try this then:
    pause 500 :next i
    SOLVED!
    It's a long story, and I'm a little embarrassed to admit it. I had issues every once in a while with strange characters displaying on the LCD. I sent one of my boards to the LCD company a few months ago and they found that I was running it slightly below the minimum voltage in the spec sheet. I had used the recommended resistor value to power, but also had something else running from the same pin which pulled the voltage something like .3 volts below spec. Replacing that resistor fixed the strange character issue. Well, when I started adding this counter to my code the other day, I grabbed one of my older boards and started testing and was having this "zero" problem.
    I just ran your code above and when "p" was the ending character, the LCD went blank. So i made a program to display a bunch of words, with some ending in "p"....went blank on every "p" ending word. In the process of testing, I broke a lead wire to the battery off for the board, and when I went out to solder in back on a few minutes ago, I noticed that this board hadn't had the resistor replaced, so I replaced it and THAT WAS THE PROBLEM!
    So, to make a long story short, the voltage for the LCd was too low.
    I sure thank you guys for your time and troubles! OK, now let the beatings begin....
    Gary
    Maybe I have missed it, but I do not see where you have turned off the comparators.
    Dec 2005
    Thanks mackrackit, I will take a look at that. I did get the problem solved though, so I am very happy!
    Gary
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  2. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 08:43
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
  5. A/D display result on LCD
    By winsthon in forum mel PIC BASIC Pro
    Last Post: - 10th January 2004, 11:09
