A/D display result on LCD
Results 1 to 16 of 16
    winsthon's Avatar
    winsthon Guest
    Default A/D display result on LCD
    Hi Im new to BASIC. I have a problem about PIC16F877 A/D...I want to display the digital output of the analog input signal and convert it as HEX value and display it on the LCD.
    I have a code using BASIC but I dont know how to display the HEX equivalent so instead I use # to display the decimal value. can anyone help me how to do this convert the decimal value into its HEX equivalent...Here's my code...
    Define ADC_CLOCK = 3 'default value is 3
    Define ADC_SAMPLEUS = 10 'default value is 20
    Define LCD_BITS = 8 'allowed values are 4 and 8 - the number of data interface lines
    Define LCD_DREG = PORTB
    Define LCD_DBIT = 0 '0 or 4 for 4-bit interface, ignored for 8-bit interface
    Define LCD_RSREG = PORTD
    Define LCD_RSBIT = 1
    Define LCD_EREG = PORTD
    Define LCD_EBIT = 3
    Define LCD_RWREG = PORTD 'set to 0 if not used, 0 is default
    Define LCD_RWBIT = 2 'set to 0 if not used, 0 is default
    Dim an0 As Word
    Dim an1 As Word
    Dim an2 As Word
    TRISA = 0xff 'set all PORTA pins as inputs
    ADCON1 = 0 'set all PORTA pins as analog inputs
    Lcdinit 'initialize LCD module; cursor is off
    loop:
    Adcin 0, an0
    Adcin 1, an1
    Adcin 2, an2
    Lcdcmdout LcdClear 'clear LCD display
    Lcdout "Hex Value:" 'text for the line 1
    Lcdcmdout LcdLine2Home 'set cursor at the beginning of line 2
    Lcdout #an0,#an1,#an2 'formatted text for line 2
    WaitMs 2000 'larger value should be used in real device
    Goto loop 'loop forever
    by the way Im using 3 analog inputs...I want to know the HEX value each of the input and display them on the LCD like FF FF FF 2 bytes only per input and display them together on the LCD. I used the PIC simulator IDE 2.9 with built-in BASIC compiler. Whats the difference between this BASIC from PIC simulator IDE and PicBASIC pro.??? Anyone I appreaciate your help.
    OK... this is for PBP... I'm not familiar with your IDE's Basic.
    LCDOut $FE,$01 ' Clears your LCD, sets cursor to Line 1 Column 1
    LCDOut "Hex Value:" 'text for the line 1
    LCDOut $FE,$C0 ' Cursor to Line 2 Column 1
    LCDOut HEX2 AN0," ".HEX2 AN1," ",HEX2 AN2 ' Formatted text for line 2
    ' Note the space between displayed values
    Pause 2000
    Refer to the PBP manuals LCDOut command to see what I've done.
    Melanie
    winsthon's Avatar
    winsthon Guest
    Default Help again
    Pause 2000
    Melanie
    About the code you gave me...I included it on my code but the compiler PBP cannot understand ADCON1 and LCDINIT. Why can revise it for Im still learning PBP. thanks.
    It's not a case of cutting and pasting somebody's code. Nothing is learnt by doing that. So, I'm going to be a little bit cruel here - but it does aid the learning process... can you find for me the command LCDINIT in section 5 of the PBP manual (to help you the commands are in alphabetical order) - What does it say?
    ADCON1 however is valid. The compiler WILL understand ADCON1 once you tell it you're using a pic16F877. By default it looks at a 16F84 which doesn't have an ADCON1 register which is probably why PBP is currently rejecting it.
    What version of PBP are you using?
    winsthon's Avatar
    winsthon Guest
    I found the LCDINIT already thanks for the advice. Im using PicBasic Pro 2.43...
    You gotta tell me what page it's on... *smiles*
    winsthon's Avatar
    winsthon Guest
    Well we might not be on the same page or same PICbasic manual but when I used LCDINIT on PIC Basic Pro 2.43 it allows to compile and assembled using MPASMWIN. Im using PIC Basic Pro 2.43 on Micro code Studio Plus. I have a question why is it the when I compiled it and assembled it on MPASMwin and run on MPLAB SIM, PBPPIC14.LIB is the one that is being simulated is this how it supposed to work? just curious...I haven't programmed it to my microchip just to make sure...and Oh by the way what PBP you are using and the compiler for ASM? can you give me a link that I can download these tools? Thanks you...
    Firstly, as far as I am aware, there is no command such as LCDINIT, therefore you should not have found it in your manual. However, saying that, the compiler should have flagged that as an error since it's not a reserved word either. I've tried several LCDINxxx words like LCDINA, LCDINITF, LCDINFRED and they all compile happilly too... so a bad mark for PBP in that respect.
    That aside, the point I'm trying to make is, that if the word isn't in the PBP manual, or it's not a valid PIC Register name it shouldn't be used. Your original example had LCDCMDOUT, LCDINIT and WAITMS none of which are valid PBP words which you would have discovered if you looked in the PBP manual. This is why I asked if you're using PBP.
    As I've just mentioned, there is NO "Initialise LCD" command in PBP. The LCD is initialised on your first instruction to it (which usually is Clear Display - eg LCDOut $FE,$01), however the LCD is a slow device to wake up at Power-On, so you should have a 1 second (or thereabouts - some LCD's need two seconds) delay in your program from power-on to allow for the LCD to settle before you output anything to it.
    I don't use Microcode Studio which is why I can't answer questions on it, but I have all the versions of PBP for the last couple of years which allows me to check for errors in older versions too. The only tools I use is MPLAB from Microchip and PBP from MeLabs. Unless I have to, I also prefer to use the MeLabs assembler which comes with PBP. Other than the manual and the PIC's Datasheets, there are no other downloads that I use.
    Melanie
    winsthon's Avatar
    winsthon Guest
    thanks for the info I appreciate your help. God Bless and more power.
    winsthon's Avatar
    winsthon Guest
    I have another problem. Im going to get the output of the analog signals via RA0, RA1 and RA3 and convert then into Binary and display on the LCD using a button. So far I have this code which I think the button didn't work. Here's the code:
    INCLUDE "BS1DEFS.BAS "
    Define ADC_CLOCK 3 'default value is 3
    DEFINE ADC_BITS 8
    Define ADC_SAMPLEUS 10 'default value is 20
    Define LCD_BITS 8 'allowed values are 4 and 8 - the number of data interface lines
    Define LCD_DREG PORTB
    Define LCD_DBIT 0 '0 or 4 for 4-bit interface, ignored for 8-bit interface
    Define LCD_RSREG PORTD 'RS port
    Define LCD_RSBIT 1 'RS pin
    Define LCD_EREG PORTD 'En port
    Define LCD_EBIT 3 'En pin
    Define LCD_RWREG PORTD 'R/W port
    Define LCD_RWBIT 2 'R/W pin
    DEFInE LCD_LINES 4 'LCD lines
    DEFINE BUTTON_PAUSE 50 'button debounce delay is 50ms
    an0 var word 'set variable an0 as word
    an1 var word 'set variable an1 as word
    B var PORTC.4 'define RC4 as pin input to select RA0 or RA1 as input
    btn var byte
    ledrc0 var PORTC.0 'set ledrc1 as RC0 indicates RA0 as input
    ledrc1 var PORTC.1 'set ledrc2 as RC1 indicates RA1 as input
    ADCON1 = 4 ' Set RA0, RA1 & RA3 as analog input
    btn = 0
    goto loop 'skip subroutine
    ra0: 'ra0 subroutine
    high ledrc0 = 1
    low ledrc1 = 0
    Adcin 0, an0
    Lcdout $fe, $01 ' Clears your LCD
    Lcdout $fe, $c0 ' Cursor to Line 2 Column 1
    Lcdout $fe, $14 ' move cursor 1 space
    Lcdout $fe, $14, " ", "RA0", " ", "VALUE:" ' Formatted text for line 2
    Lcdout $fe, $94 ' cursor to line 3
    Lcdout $fe, $14, BIN8 an0 ' Formatted text for line 3
    ra1: 'ra1 subroutine
    high ledrc1
    low ledrc0
    ADCIN 1, an1
    Lcdout $fe, $01 ' Clears your LCD, sets cursor to Line 1 Column 1
    Lcdout $fe, $14, " ", "RA1", " ", "VALUE:" ' Formatted text for line 2
    Lcdout $fe, $14, BIN8 an1 ' Formatted text for line 3
    loop: 'main
    Button B,1,10,5,btn,0,loop
    if btn = 1 then
    Gosub ra1
    gosub ra0
    Anyone I need help with buttons as to which pin I will connect it and how to declare them correctly...Thank you...
    winsthon's Avatar
    winsthon Guest
    hi seems that no one wants to reply...please anyone I need your help or at least give me an idea and also can I ask what does this mean:
    whats the difference between these two?
    ADCON1 = %00001011
    ADCON1 = 4
    option_reg = $7f
    OPTION_REG.7 = 0 'Enable PORTB pull-ups
    TRISB = %11110000
    what does $7f do, anyone who can show me something like the one above.
    Patience. Posting a question in the middle of international holidays, or weekends, or in the festive season and expecting immediate replies is being a little optimistic - especially as some of your questions require a little more than a quick two-minute answer!!! I will get around to answering your previous question with time.
    ADCON1 = %00001011
    ADCON1 = 4
    I assume you're using a 16F877... please download the datasheet and look in section "11.0 Analogue to Digital Converter Module" - it's right at the start of that section.
    >option_reg = $7f
    Again look at the OPTION_REG in the PIC's Datasheet. You will find it in the "Memory Organisation" section 2.2.2.2... Adobe provided you with a search facility within the Acrobat Reader if your Datasheet differs from mine.... However $7F is in binary %01111111, bit 7 is zero, all the other bits are one. Cross-check the setting of those bits against the table in the Datasheet detaling each bit of OPTION_REG.
    Melanie
    winsthon's Avatar
    winsthon Guest
    thanks mel for the information. About also to my previous question regarding dealing with buttons. Until now I cant get it, I hope you can give me an idea on how to deal with buttons.
    I want to get the corresponding digital output of the 3 analog inputs namely RA0, RA1 and RA3 one at a time by using a buttons such that when I press the first button it will enable RA0, if button2 enable RA1 disable RA0 and RA3 and lastly if button3 is pressed it will enable RA3 and disable RA0 and RA1. Maybe buttons will be connected to PORTC because PORTB and PORTD are being used already for the LCD.
    With regard to a Button selecting a input... your original example used PortC.4 for the button, so we'll carry on using that...
    Button is connected between PortC.4 and 0v (Vss). A pull-up Resistor (10K) is connected between PortC.4 and +5v (Vdd).
    PushButton var PortC.4
    When button is pressed, the status of PushButton will be zero (Low), when button is released, the status will be 1 (High).
    We'll also use a variable...
    ButtonCounter var Byte
    We will increment this variable each time button is pressed, and depending on the state of the variable, we will display one of your three inputs...
    ButtonCounter=0
    LCDOut $FE,1
    ' initially clear screen ready for display
    Loop:
    If PushButton=0 then
    ' Button has been pressed
    LCDOut $FE,1
    ' Clear screen indicating to user that Button has been pressed
    While PushButton=0:Wend
    ' Wait for button to be released
    ButtonCounter=ButtonCounter+1
    If ButtonCounter=>3 then ButtonCounter=0
    ' ButtonCounter only counts 0,1 or 2 then starts over again
    If ButtonCounter=0 then Gosub DisplayFirstADC
    If ButtonCounter=1 then Gosub DisplaySecondADC
    If ButtonCounter=2 then Gosub DisplayThirdADC
    goto Loop
    Have fun...
    Melanie
    winsthon's Avatar
    winsthon Guest
    thanks mel, with that it helps me a lot to gather data from the ADC. Now that I have the data I just want to ask about SELECT CASE, you see I have a program that uses if...then...else..enif and my code was so long I need to shortened it using SELECT CASE. on the if..then.. command I can have two arguments like
    if x<=100 and x<=200 then
    I tried select but it doesnt have AND/OR. Is there any other way to shortened my program to make my program execute faster?
    Do read the PBP manual... Section 4.19 on Logical Operators, see the table therein and the example provided underneath.
  1. LCD Display
    By lambert in forum mel PIC BASIC Pro
    Last Post: - 16th January 2010, 23:18
  2. assembly in Pic
    By lerameur in forum Off Topic
    Last Post: - 1st May 2008, 21:06
  3. LCD display not working properly
    By dilpkan in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2008, 08:43
  4. Replies: 14
    Last Post: - 26th September 2007, 06:41
  5. LCD Display not working - PIC heating...
    Last Post: - 24th September 2006, 08:35
