Maixium voltage on a input pin
Results 1 to 20 of 20
    Hi, Robert
    I think we mixed DIGITAL and ANALOG inputs ...
    here you want 0 > 12 v to be 0 > 5 v !!!
    so, you need a voltage DIVIDER ...
    see Darrel's site for such an application :
    http://www.pbpgroup.com/modules/wfse...p?articleid=25
    Everything explained ...
    Yup, the signals from the sensors will be analog. Interesting tool, I added it to my favourites. There is a comment at the bottom of that page that puzzles me though:
    "Do not use the Zener diode (D1) for analog circuits. It will adversely affect the readings.
    It can be useful for protection of Digital Inputs though."
    So, since I've lowered the voltage to an acceptable level for the PIC, then there should not be any need for extra clamping diodes, no?
    Lightbulb
    It's an automotive environment ( remember the 45v ??? ) ... use clamping diodes instead of the Zener ... they won't disturb the divider.
    In post #19 and #28 of this thread http://www.picbasic.co.uk/forum/show...ighlight=zener
    Melanie talks about the zener.
  1. Is this a K Type sensor?
    Last Post: - 21st November 2009, 13:55
  2. make a low voltage output from a PIC pin
    By emptyset in forum General
    Last Post: - 8th February 2008, 19:20
  3. Microcontroller with 2 way paging application problem
  4. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
  5. Another RTC, DS1287
    Last Post: - 12th December 2006, 17:07
