Interrupts Identification (handling)
Results 1 to 6 of 6
    May 2007
    Question Interrupts Identification (handling)
    Hello all again;
    In a program I want to do, I want to handle more than an interrupt source, so I enable theese interrupts:
    -RB Port Change Interrupt
    -Timer1 Overflow Interrupt
    in the ON INTERRUPT part, ¿How can I identify which interrupt was triggered?
    (if relevant, PIC is a 16F628A)
    regards
    Rod
    "Beethoven had his critics too, see if you can name 3 of them"
    Post
    Just check if corresponding interrupt flags are set ... before clearing them !
    that's all !
    May 2007
    that's all !
    LOL so simple ! thank you.
    -something like:
    ON INTERRUPT GOTO IntHandler
    IntHandler:
      If PIR1.0=1 then
         PIR1.0=0 'Clear flag
         ..do my thing...
         RESUME
      EndIF
      If INTCON.0=1 then
         INTCON.0=0 'Clear flag
         ..do my thing...
         RESUME
      EndIF
    but.. if I have 10 interrupts enabled and the last interrupt checking ('If' statement) was the triggered, will I always have to check the previous 9 each??, sounds like it will.
    PD: ENABLE & DISABLE are optional, am I ok?
    Why not use Darrels Interrupts?
    Quote Originally Posted by RodSTAR View Post
    -something like:
    [code]
    Yess ... so simple
    You see anther way to check which has triggered ???
    it's a Pic specifics !!!
    heuuuuu, disable before the interrupt stubb !!! or it will be fun ...
    Ioannis ( hello ...) is right ... BUT if your device shows ~> 2K prog space min. ( say ~> 100 SRAM Bytes ...). The 12F683 is the minimum size to allow something "usable" ...
    Hi Alain. He stated that the device is F628, so it might fit the budget! But on the other hand, On Interrupts, depending on the length of the PBP program might consume RAM too.
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  2. Clock using Instant Interrupts
    By PICpocket in forum mel PIC BASIC Pro
    Last Post: - 16th February 2009, 21:43
  3. Handling External/Timer Interrupts
    By Tacky3000 in forum mel PIC BASIC Pro
    Last Post: - 3rd December 2008, 11:09
  4. DT's Instant Interrupts trouble
    Last Post: - 24th November 2008, 20:48
  5. help: TMR0 interrupts disabling PORTAchange interrupts???
    Last Post: - 19th August 2008, 15:10
