Nokia COLOR LCD PicBasicPro 2.50a example code
Results 1 to 40 of 50
    Mar 2008
    Gerogetown, Texas
    Skimask
    The splash screen is 8bit but the picture is 12bitB. When I played with it I tried all three possibilities. All worked you just need to change the configuration command on the display.
    It took me a while to get the VB6 program to read the file from the converter. The problem was at the end of each line of data VB6 tried to send a "0" which caused the display to be skewed. I finally sorted it out and all was well.
    I did not try an external eeprom yet. The color picture was to big to fit into the PBP code. Or at least I could not figure out how to get it in without exceeding the size limit.
    It would be easy enough to make a photo album that changes the image every so many seconds/minutes. Maybe someone will put a compact flash or SD ram with this display. I do not think it would be that hard.
    I have no real practical application for this screen, I just wanted to see if I could get it to work.
    By the way, I used your text macro. Thanks it worked great!
    Quote Originally Posted by DaveC3 View Post
    Don't blame me for that one!
    That's mostly DT's work (or was it Mr_E?, I forget).
    I only modified it a bit to work with my application.
    Default Using Nokia code above 64K
    I found this little bug today while working with my 18F4685, trying to use the functions in code space above 64K...and it ONLY applies to PBP 2.50A (and above I'm sure whenever it comes out) and will most likely apply to most other little routines like this running on PICs with more than 64K (i.e. 18F4685, 18F8722, and so on), like the @printstr, @copystr, whatever, whether sending to a graphic LCD, serial port, whatever.
    ASM	;printstr to color LCD macro,	'@ printstr x,y, "string to lcd at x,y"
    printstr	macro clcdx, clcdy, clcdstr
    		local clcdthestring, clcdoverstr
    		bra clcdoverstr
    clcdthestring
    		data clcdstr,0
    clcdoverstr
    		MOVE?CB clcdx, _clcdpx
    		MOVE?CB clcdy, _clcdpy
    		MOVE?CW clcdthestring, _clcdaddr
    		L?CALL _clcdstringout
    The 3rd line from the end: MOVE?CW clcdthestring, _clcdaddr won't grab the upper bit of the PC and ends up reading the codespace at the lower 64K block instead of the upper 64K block.
    The fix is simple enough.
    Declare clcdaddr as LONG rather than WORD, and change MOVE?CW to MOVE?CN. All it does it changes moving a WORD to moving a LONG.
    All better...
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. PicBasicPro Code help!
    By michel in forum mel PIC BASIC Pro
    Last Post: - 14th June 2008, 16:43
