Pic Basic TouchScreen? How?
Results 1 to 19 of 19
    Begin with the following...
    http://www.picbasic.co.uk/forum/show...44&postcount=7
    Then send your results to your PC or any LCD, then try to understand what happen.
    Mar 2008
    Then what if i use that touchscreen controller, then i shouldn't High any ports, should i?
    Yes, you'll still need to play with high/low, ADC conversion etc etc... hence why i told you that you don't need it.. even your new compiler haven't it built-in
    Mar 2008
    New Compiler?
    But could you please look at this datasheet, and tell me what ports that should go to what (X+, X-, Y-, X- as there is in the PBP code, but this have some others)
    http://www.mikroe.com/pdf/touchpanel...matic_v102.pdf
    North Norfolk UK
    Quote Originally Posted by mindthomas View Post
    See your other thread of endless how-to posts...
  1. Sending Commands from Visual Basic about IR to Pic
    By tne_de in forum mel PIC BASIC Pro
    Last Post: - 29th April 2009, 07:09
  2. Loop with two motor and 2 sensors
  3. using AND as an IF statement
    By dw_pic in forum mel PIC BASIC
    Last Post: - 8th June 2006, 19:05
  4. vb6 to pic basic
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 19th December 2005, 02:56
  5. The Ultimate PIC Basic
    By picnaut in forum PBP Wish List
    Last Post: - 9th November 2004, 23:10
