What does this do, and would it be easier to use a touchscreen if i buy this:
http://www.mikroe.com/en/tools/touchcont/
It's exactly the same draver as Alain's EasyPIC 5 board.
It may help.. but i stand to tell you don't need it.
Begin with the following...
http://www.picbasic.co.uk/forum/show...44&postcount=7
Then send your results to your PC or any LCD, then try to understand what happen.
Yes, you'll still need to play with high/low, ADC conversion etc etc... hence why i told you that you don't need it.. even your new compiler haven't it built-in![]()
