Replacing shift register with PIC
Results 1 to 7 of 7
    Apr 2006
    The pic would only be receiving clock data and latch data from the master in my case.
    And then it would only need to send serial data, and (clock data?) back out to the master.
    I'll post my code and try to clarify this a bit. Thanks for your reply.
    T
    Quote Originally Posted by TonyA View Post
    T
    Just read the rest of your 1st post.
    Yes, if the NES is sending out a clock, then that would make your PIC a slave device, clocked by something else.
    Most PICs support both master and slave SPI operations.
    Apr 2006
    Yes, right the pic would be a slave. Here is what I have.
    shiftin latchPin_in, clockPin_in, MSBFIRST, [latch_receive, clock_receive]
    ' clockPin_in is a pin on the pic that is attached to the clock line of the NES gamepad port
    ' latchPin_in is a pin on the pic that is connected to the latch line of the NES gamepad port
    if latchPin_in = 0 then 'if we receive a zero from the master's latch output data then shiftout serial data.
    shiftout serialOut_pin, clockPin_in, MSBFIRST, [serial data output] 'send a byte out to the master.
    In this case what do I do with the clock data received when shifting in? I'm not sure how to handle the clock data received.
    Does a 4021B shift register (slave) receive latch and clock data in a standard (fixed) way? Or does this rely on how the latch and clock data are being sent from the master?
    You said I would "tie up" the pic doing this. If that's true than maybe I'll skip this and just use a pic to send the parallel input into a real shift register, then out to the master.
    I was thinking about using a pot via ADCIN and then send the shifted out serial bits based on the pot reading. Would that work with shiftin and shiftout going on as well?
    Thanks again,
    T
    Datasheets for the 4021 should tell you all you need to know...about the 4021.
    I guess the main thing would be to 'scope out what the NES is sending out, figure out how fast it's going, what it's logic levels are, and so on.
    Shiftin/Shiftout are both 'blocking' commands. You can't do anything else until the commands are done executing because it's all done in software.
    If you used the MSSP module in a PIC, you could just punch a byte to the TX register, hit a bit to send it, and go about your business. When you have another byte to send out, check the busy bit, if it's good, send another byte. The MSSP does all the clocking and shifting in hardware.
    Depends...on the time it takes to read the pot, how fast shiftin/shiftout run, among other things...
    You could start the ADC, shiftout a byte. By the time a byte is shifted in or out, the ADC would be finished and ready for a read. Then restart the process...
    Apr 2006
    Thanks again for your help, sincerely appreciate it.
    (Will experiment)
    Tony
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 21:31
  2. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  3. Replies: 14
    Last Post: - 26th September 2007, 06:41
  4. Use the PIC 16f877 or 877A instead of shift registers.
    By tsanders in forum mel PIC BASIC Pro
    Last Post: - 27th October 2006, 18:23
  5. Replies: 15
    Last Post: - 30th January 2005, 04:58
