Pullups and pulldows
Results 1 to 19 of 19
    I'm kinda lost in here... sorry And there's some danger also.. unless you also use a current limiting resistor between your PIC and the mag.... hence why i asked for a schematic awhile back... and weak pull-up can't be tied to GND... unless it would be pull-down.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    I will make a schematic/diagram with the stuff by draw it by hand will be a mess. I will try to understand how to use EAGLE pcb designer so I make some decent diagram.
    In the meantime, as I said, the two pics have to communicate using each one porta pin.
    The communications is:
    Gun-PIC send +5V to Mag-PIC who then turns its pin as output and sends back a +5v to the Gun-PIC.
    I'll make my schematics and system description and source available on my website by the end of the week.
    Anyway THANKS a lot for your help guys.
    xnihilo's Avatar
    xnihilo Guest
    Sure, pull-down because I use the pin in low state so to avoid the pin to be left floating I tie it to GND, I read it is a good practice.
