Long storyPM or e-mail....
Yep, that is why I think a 100K might be better in you situation.What will happen when the 5V output is sent. As there is a 10K weak pullup connecting the pin to the ground... I guess some current will sink to the ground but most of it will reach the target pic, right?
I think![]()
I'm kinda lost in here... sorryAnd there's some danger also.. unless you also use a current limiting resistor between your PIC and the mag.... hence why i asked for a schematic awhile back... and weak pull-up can't be tied to GND... unless it would be pull-down.
I will make a schematic/diagram with the stuff by draw it by hand will be a mess. I will try to understand how to use EAGLE pcb designer so I make some decent diagram.
In the meantime, as I said, the two pics have to communicate using each one porta pin.
The communications is:
Gun-PIC send +5V to Mag-PIC who then turns its pin as output and sends back a +5v to the Gun-PIC.
I'll make my schematics and system description and source available on my website by the end of the week.
Anyway THANKS a lot for your help guys.
