Strange electrical behavior with PIC16F684
Results 1 to 11 of 11
    No pull-up or WPU... the i/o is set as an output and set to low and AN INT happen???? huh???? I must miss something here!
    Maybe i'm blind... but i don't see any cod in here... so i would assume the TRIS register haven't been changed. Try LOW PORTA.5 instead.. if this work.. it just mean you didn't at least changed TRISA setting....or the INT don't care about the TRIS... i'll check the datasheet...
    xnihilo's Avatar
    xnihilo Guest
    Yes an int happens... No clue why it happens.
    I didn't put any code here but beleive me,
    TRIS is set as 0 (output) for RA5 and I used PORTA.5 = 0 to be sure it has been set LOW.
    I beleive the pin should be low and an int should be triggered when I apply +5V on the pin to set it logicaly HIGH but that's not what's happening.
    And an int happens for this pin even in I touch another pin or even the GND heatsink of the L7805 voltage regulator or +5V or GND...
    I checked the connexions on the breadboard and everything looks fine...
    Very frustrating.
    obviously, there's something else... great news i have over 500 of those in stock
    i'll try a simple snippet and see what happen. I would guess the interrupt will happen 'cause it's feeded in a X way inside. Probably you will need to disable the interrupt as well...
    let's see what will happen on my side in a few minutes.. gimme 1/2 hour + couple of RedBull+Amaretto (even if i shouldn't... don't tell to my doctor )... or so.
    unable to reproduce the problem here...
    post your code.
    xnihilo's Avatar
    xnihilo Guest
    post your code.
    You don't have exactly the same components and connexion
    How can I discover the source of the problem... I will have to rebuild a clone of the system but this time not on a breadboard.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    let's see what will happen on my side in a few minutes.. gimme 1/2 hour + couple of RedBull+Amaretto (even if i shouldn't... don't tell to my doctor or so.
    Redbull + Amareto... Thats GEEK stuff
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 09:47
  2. Strange pic 16f877a memory loss
    By DavyJones in forum General
    Last Post: - 6th July 2009, 20:27
  3. Electrical Current Does Prevent Corrosion?
    By T.Jackson in forum Off Topic
    Last Post: - 18th March 2008, 13:13
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 14:19
  5. Strange ASM file
    By barkerben in forum General
    Last Post: - 29th November 2004, 18:54
