Strange electrical behavior with PIC16F684
Results 1 to 11 of 11
    obviously, there's something else... great news i have over 500 of those in stock
    i'll try a simple snippet and see what happen. I would guess the interrupt will happen 'cause it's feeded in a X way inside. Probably you will need to disable the interrupt as well...
    let's see what will happen on my side in a few minutes.. gimme 1/2 hour + couple of RedBull+Amaretto (even if i shouldn't... don't tell to my doctor )... or so.
    unable to reproduce the problem here...
    post your code.
    xnihilo's Avatar
    xnihilo Guest
    post your code.
    You don't have exactly the same components and connexion
    How can I discover the source of the problem... I will have to rebuild a clone of the system but this time not on a breadboard.
    xnihilo's Avatar
    xnihilo Guest
    Smile
    let's see what will happen on my side in a few minutes.. gimme 1/2 hour + couple of RedBull+Amaretto (even if i shouldn't... don't tell to my doctor or so.
    Redbull + Amareto... Thats GEEK stuff
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 10:47
  2. Strange pic 16f877a memory loss
    By DavyJones in forum General
    Last Post: - 6th July 2009, 21:27
  3. Electrical Current Does Prevent Corrosion?
    By T.Jackson in forum Off Topic
    Last Post: - 18th March 2008, 14:13
  4. PIC16F684 + LCD to use the 256bytes of EEPROM - HELP
    Last Post: - 7th March 2008, 15:19
  5. Strange ASM file
    By barkerben in forum General
    Last Post: - 29th November 2004, 19:54
