parallel port interfacing - 16f84
Results 1 to 13 of 13
    Quote Originally Posted by devil6600 View Post
    hello all,
    I want to read some data from the parallel port of my PC, the data would be in the from of strings. After some research I came to know that parallel port sends data bitwise (set of 8 bits). Now I do not know how to read each bit. Would it require the use of buffer IC's?
    I don't know how to do it. Any help is solicited.
    My target uC is 16f84
    Thanks.
    Parallel port operation is well document throughout the Internet, literally millions of hits on a Google search as well as here.
    As far as using an 'F84, how many bits do you plan on transferring at a time?
    8 bits is going to be a bit difficult and still have enough pins left over to control....anything...
    How much other PIC programming have you done so far?
    Mar 2008
    Madhya Pradesh, India
    I haven't used any other PIC.
    well, what I want to do is to store the incoming data from the parallel port into a variable. Now, let us suppose once the PORTA has been set to be input (trisa = %11111111), then how to read the value of all the pins in PORTA and store them in a variable?
    suppose if the incoming data is say "2" whose binary equivalent is 00000010, so now how to read this value on PORTA pins & store it in a variable?
    thanks
    Mar 2008
    Texas, USA
    trisa = %11111111
    Variable var byte
    Variable = PORTA
    ... but that won't work on PORTA with 8-bit data. Read the datasheet.
    I haven't used any other PIC.[........suppose if the incoming data is say "2" whose binary equivalent is 00000010, so now how to read this value on PORTA pins & store it in a variable?
    At the risk of being wrong...'cause it's entirely possible...
    Before you go messing with a parallel port and blowing it up, I'd suggest you go for Mr. Blinky LED first, then throw a button or two into the mix, add an LCD, and so on.
    If you don't know how to assign a value from a port to a variable, then how do you expect to do any handshaking with a parallel port?
  1. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 13:25
  2. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 23:35
  3. Microcontroller with 2 way paging application problem
  4. parallel port multi pic programmer?
    By SuB-ZeRo in forum Schematics
    Last Post: - 25th June 2005, 11:20
  5. STATUS re-curtain W
    By zugvogel1 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2005, 16:21
