Eeprom 24lc256
Results 1 to 8 of 8
Thread: Eeprom 24lc256
    Mar 2008
    Unhappy Eeprom 24lc256
    This program works well whit EEPROM 24LC02B street I2C with the pic16F84A.
    With the EEPROM 24LC256 and 24C32 don't work.
    There are not other EEPROM in fall therefore byte of control is "% 10100000."
    Help..
    '16F84A scrittura su EEPROM
    INCLUDE "Modedefs.bas"
    DEFINE CHAR_PACING 10
    SCL Var PORTA.1
    SDA Var PORTA.0
    Addr Var byte
    E_ByteOut Var Byte
    E_ByteIn Var Byte
    serout PORTB.4,2,[12,1]
    For Addr = 0 To 50
    E_ByteOut = Addr*3
    I2CWRITE SDA,SCL,%10100000,Addr,[E_ByteOut]
    Pause 10
    Next Addr
    For Addr = 0 To 50
    I2CREAD SDA,SCL,%10100000,Addr,[E_ByteIn]
    serout PORTB.4,2,["Indirizzo = "]
    serout PORTB.4,2,[#Addr,10,13 ]
    serout PORTB.4,2,[" EEPROM = "]
    serout PORTB.4,2,[#E_ByteIn ]
    Pause 100
    Next Addr
    Mar 2008
    Help..
    '16F84A write on EEPROM
    SCL Var PORTA.1
    SDA Var PORTA.0
    Addr Var byte
    E_ByteOut Var Byte
    E_ByteIn Var Byte
    For Addr = 0 To 50
    E_ByteOut = Addr*3
    Pause 10
    Next Addr
    For Addr = 0 To 50
    Pause 100
    Next Addr
    THX chip_s
    Mar 2008
    Help..
    SCL Var PORTA.1
    SDA Var PORTA.0
    Addr Var byte
    E_ByteOut Var Byte
    E_ByteIn Var Byte
    For Addr = 0 To 50
    E_ByteOut = Addr*3
    Pause 10
    Next Addr
    For Addr = 0 To 50
    serout PORTB.4,2,["Addr = "]
    Pause 100
    Next Addr
    THX chip_s
    Mar 2006
    China
    Default maybe
    Maybe you should consider if a byte is really enough for the addressing. It could be that a really tiny ee2 has a byte as address but the bigger ones might need a word.
    you can probably see this in the datasheet :-)
    24lc02b (256 * 8 bit) so a byte is nice for this.
    24lc32 (4K *8 bit ) so here we need more than a byte for addressing
    /me
    Mar 2008
    Default replay
    Then as I can modify my program?
    chip_s
    Just look at how the 3 MSB addresses must appear ... ( AKA ... see datasheet ! )
    I think a SEARCH will show you the subject is well known ...
    Or unknown apparently!
    Mar 2008
    Texas, USA
    The address is a word on this eeprom, not a byte. PBP catches this automatically. Just change the address to a word (2 byte address data size)
    Addr Var byte > Addr Var word
    Oh, and STOP the spam!
    No, I'm not Superman, but I did stay at a Holiday Inn Express last night!
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  4. Pic16F628A and 24LC256 EEPROM I2C
    By Mike96 in forum mel PIC BASIC Pro
    Last Post: - 1st January 2006, 03:13
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
