Where should I discuss SD/MMC FAT issues?
Results 1 to 40 of 93
    Mar 2008
    Texas, USA
    Hi Skimask,
    Isn't the file size in FAT32 stored at 2 different places? And both of them have to be identical? I forget...it's been awhile since I read the FAT32 documentation...
    Sorry, I forgot to say that I'm using FAT16 when I format the MMC. It's the native format that the MMC's came with. I don't know what version of FAT16 I'm using. I understand there at least several versions or revisions to the FAT16 system. The MMC's I'm using are 128MB in size.
    ...look into the F-RAM options.
    Yes, for a final in-field application this would be the way to go. As it is, I'm cheap and have the EEPROM's on hand. My application is data recording at about 100 sectors a second. For writing the data it will be sent directly to the card. The EEPROM use in my ap would only be at the first and end of the recording events (about 10-15 minutes long) and this would be just to address the FAT issues.
    I'm back off to some of my web haunts where I've been reading about FAT16. Maybe I'll find the answer by going back over these sites. I do have this odd recollection of there being some part of the FAT where data is written LSByte first. Maybe it was the file size?
    Gary
    Quote Originally Posted by JD123 View Post
    That fat32 document has a load of info in it, and specifies where it differ's from fat16...not that it matters much
    I was able to shove a bit over 600K/sec into the CF card on my player, but that's using the IDE mode, parallel data transfer. 600K was as fast as the PIC could go @ 40Mhz.
    You'll be limited to the max SPI speed, and I think you'll be lucky to be able to handle 100 sectors/second (100 sectors = 512000 bytes = 5.12mbps) and still have any time leftover to do any sort of interrupt processing.
    Do a search for fatgen103.doc and you'll see what I'm looking at.
    And yes, offset 28 is the file size, and yes, it is LSB first...little endian...
    Mar 2008
    Texas, USA
    YES! I came back here to say I found this, only to see you found it too. The size IS written LSByte first. I can't tell you how many places on the web fail to state this. This is what I just now found:
    data length ( =4 bytes )
    the minimum can be 00 00 00 00 - 0 and the maximum ff ff ff ff -
     4,294,967,295
    gb, mb, kb, by
    this entry will state the length of data to read in.
    eg, AC 3B 96 00
    flip these values: 00 96 3B AC
    convert to decimal: 9,845,676 bytes or 9.38MB
    folders have a value of: 00 00 00 00
    Thanks guys for getting me out of this ditch. It's amazing how much time I waste on some of the 'simplest' problems.
    skimask, thanks for letting me know what you were able to get for speed. I'm shooting for 100, 8 byte recordings per second, but if I can make 60 I'll be happy. The recordable rate will be selectable and I was picking 100 as a top-shelf goal.
    Edit: skimask, sorry... I see what caused the issue about speed. I originally ment to say ONE sector per second, not 600. 600 is the byte rate, not the sector rate. I guess I really WAS pushing the limits, the way I originally stated it!!!
    100 8 byte recordings per second? That's only 800 bytes... I said 600KB per second, as in, 614,400 bytes per second, 6,144,000 bits per second.
    But again...it was a parallel operation.
    Now are you talking 100 8 bytes recordings...
    or 100 512 byte (sector) recordings
    Mar 2008
    Texas, USA
    Yes, I messed up. See my edit.
    That should be quite reachable. The real issue is reading the PWM outputs from the accelerometers and an airspeed pressure sensor. My co-worker on this project wants to read the PWM as filtered analog resolved from a 1ms PWM frame rate. I'm arguing that I can get everything done and more in the 16.66ms that we have at 60 recordings per second. Also, using the CCP and MUX'ing the inputs I can get rock solid data with a 5000 FS range. On a +/-10G accelerometer that will be .4mG resolution - well enough for what we are doing.
    Gary
    Mar 2008
    Texas, USA
    I'm not going to turn this into a thread of me talking to myself, but I wanted to say that I put a 24LC16 on the pic and I'm now reading the directory table into memory, working on it and writing it back to the MMC without any problems. The PC now accepts the modified files with the correct file information from the MMC.
    Reading out of the MMC to the I2C takes ~3 seconds for a 512 sector. I'll be getting it faster by coding for loading the 16 byte buffer on the I2C.
    So it was the file size issue then?
    Post some code. I'm sure there's a way to make it faster... It only took my code about 7-ish seconds to erase a full 24LC256 (32Kbytes), while displaying the current address on an LCD.
  1. Reading and Writing from SD/MMC cards as FAT filesystem?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2006, 22:26
