Where should I discuss SD/MMC FAT issues?
Results 1 to 40 of 93
    Quote Originally Posted by JD123 View Post
    The PC now accepts the modified files with the correct file information from the MMC.
    So it was the file size issue then?
    Reading out of the MMC to the I2C takes ~3 seconds for a 512 sector. I'll be getting it faster by coding for loading the 16 byte buffer on the I2C.
    Post some code. I'm sure there's a way to make it faster... It only took my code about 7-ish seconds to erase a full 24LC256 (32Kbytes), while displaying the current address on an LCD.
    Mar 2008
    Texas, USA
    I'll post the code if you promise not to laugh. When I'm in the R&D phase my goal is to understand, not to write pretty code. All I'm doing right now is building a reference for dealing with the MMC when I make a final application.
    I'm at work (work has nothing to do with PICs) and the files are at home. No internet at home (yes, I live in a cave... next-door to Osama) so it will be a day or two before I get it up. Most likely I'll have the code faster by then as tonight I'll probably change it to write the page buffer on the I2C memory. I started with the recommended 10ms delay after a write and once things were stable, I moved it to 5ms. Next step will be polling for busy for the shortest delays.
    The difference between R&D code and pretty code is....who cares...
    5ms is max. write cycle time for the 24LC16 (byte or page).
    You start writing 16 byte pages, and it should speed up by a factor of about 16, with the same 5ms delay after the 16 byte packet is sent out.
    Mar 2008
    Texas, USA
    Oh, and yes, the issue about the PC not 'seeing' the complete file was the file size information at offset 28 in the directory table. What you said about flipping the size to LSB first works well.
    For giggles and grins I formatted the MMC as FAT32 and tried to work with the FAT. Let's just say... NOT! I'll stick with FAT16 as long as I can. Does Vista allow FAT16 and or format media cards in FAT16? Thought I heard somewhere that FAT16 support was dropped.
    In that document, it specifies the cluster count cutoff for determining if something is formatted in FAT12/16/32.
    If FAT16 was dropped, I would infer that FAT12 would've been dropped, which means no more floppies at all.
    If you read that document, FAT32 is easy to work with, just have to take heed of the differences. The thing that's a real pain is the long filename's that come with it. But if you ignore those and stick with 8.3, FAT32 is a piece of cake.
    Default MMC specification - free
    Mar 2008
    Texas, USA
    Thumbs up
    Quote Originally Posted by BrianT View Post
    Thanks Brian. I have a copy of that. It reads like the USA budget passed by Congress :0 I couldn't find any information about FAT in the doc, though it may be in there.
    Last night I decided to see if I could find a file armed only with the file name. I was able to do it. I started to write a post that cuts to the chase in explaining how I find a file but decided if I was going to get up in the morning, I'd have to finish it later. I'll post it when it's finished. It will be a real time saver for the first-time MMC user.
    In short, I only need to read a few items from the MBR, Partition Record and the Directory Table (I think that's all I was reading - it was late). It's not hard once I know what to look for and stay within the structure of the FAT.
    Wink Example ???
    Hi, JD ( Pffffff !!!!)
    If you're interested ... I've such a project with a 18F452 ... but Written In MikroC ...
    not so far from Basic.
    I do not know why, but I think you'll be Ok ...
    PM me a mailBox address if needed ...
    Mar 2008
    Texas, USA
    Hi Alain,
    Thanks for the offer. I'll take you up on that. My next step is getting some intelligent information about adding files and making sure things like overwrites and PC compatibility are handled correctly.
    BTW, I recognize you from RCG.
    Gary
    [email protected]
  1. Reading and Writing from SD/MMC cards as FAT filesystem?
    By charliez in forum mel PIC BASIC Pro
    Last Post: - 22nd June 2006, 23:26
