How to force a 16F628A to reset using PBP statement.
Results 1 to 9 of 9
    You could use the WDT, but then you would need to insert an assembler routine that looped
    until the WDT reset the PIC. Otherwise PBP will automatically clear the WDT.
    You have the option of telling PBP not to clear WDT, but then it's up to you to manage it,
    and that can really be a pain.
    Another option is to just jump to location 0. PCLATH=0 followed by @ GOTO 0 works if you
    just want to start over from 0.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Jan 2006
    Istanbul
    Bruce,
    Could you be a little more specific with your example please?
    Sure. If you want to re-start from location 0, then;
    X VAR BYTE
    TOGGLE 0
        FOR X = 0 TO 50
         IF X = 20 THEN
          PCLATH = 0
          @ GOTO 0 ' start over from 0 if X = 20
        NEXT X
        GOTO Main
    This isn't exactly the same as a hardware reset, but it's close.
    -Bruce
    tech at rentron.com
    Jan 2006
    Istanbul
    Thanks Bruce.
    Since you say that it is not a hard reset but close, will this clear any return addresses in the stack if there is any?
    Thanks.
    No it does not clear the stack.
    -Bruce
    tech at rentron.com
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. Indexer not indexing...a basic PBP problem??
    By jellis00 in forum General
    Last Post: - 24th March 2009, 17:53
  3. Help Pbasic to PBP
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 2nd March 2009, 19:35
  4. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  5. Compiler differences between PBP 2.33 & 2.46
    Last Post: - 2nd May 2006, 20:01
